Results 1 to 9 of 9
Thread: Rear Brakes...
    Senior Member Three Rings Avant1.8BT's Avatar
    Nov 05 2006
    mycar
    Rear Brakes...
    Time to replace my rear brakes, pads & rotors. was just curious to see what you guys are using. my plan was to get some oem rotors of ECS i will call the dealership but i dout its cheaper their. and for pads not really to sure, so would need some help their. thanks!
    Senior Member Three Rings edwardabodnar's Avatar
    Mar 08 2008
    Miami
    Re: Rear Brakes...
    I had mine replaced today by a friend of mine. He replaced the pads with OEM but for the rotors he took them to a machine shop to be resurfaced and then threw them back on. I was curious if anyone has any bad news for me for doing that.
    Mar 23 2008
    Queens Ny
    Re: Rear Brakes...
    nobody really resurfaces rotors anymore. replacement rotors are so cheap neway but i dont see anything really wrong with resurfacing as long as its still thick enough
    981CGTS, Cayenne Turbo, '22 A4 Allroad
    Chicago 'burbs
    Re: Rear Brakes...
    Quote Originally Posted by edwardabodnar View Post
    On my S4 rears, I resurfaced them for $10 each, after the machining they were near the thickness that required replacement. So they only lasted about another 15k miles. When I replaced them new ones cost $34 each and should last 70k miles or so.
    2014 A4Q Red w/ black optic black interior
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Re: Rear Brakes...
    I'm running zimmerman drilled and hawk hp plus pads. I love it!
    TEAM|AXION
    Nov 05 2006
    mycar
    Re: Rear Brakes...
    bump anyone eles?
    Registered Member Two Rings NakedDave8's Avatar
    Dec 20 2006
    1999 A4 2.8Q
    Scarborough, Maine
    Re: Rear Brakes...
    Zimmerman cross drilled rotors and ebc red stuff ceramic pads. I'd go with Mintex Reds if I were you though, very worth it.
    A4 2.8 Quattro cross drilled rotors, ceramic pads, tint, Bilstein struts, H&R Race springs, 8000K Headlights....supercharger in the near future
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: Rear Brakes...
    I'm a big fan of the Axxis Ultimate Ceramic pads but you should run them at all four corners. Any pad should be run at all corners unless you are trying to correct an imbalance.
    Jim
    I Do Werk.
    Nov 05 2006
    mycar
    Re: Rear Brakes...
    im just replacing my rears right now, i will do the fronts at the end of june and up grade to a8 rotors. so whatever pads i put on the rear i will match with the fronts in june.
