Results 1 to 7 of 7
Thread: Humming noise
    Veteran Member Two Rings
    Apr 20 2004
    Portland, OR
    Humming noise
    So, something interesting is going on with my 2004 A4. There is a medium-pitched hum that comes from somewhere (can't tell where) whenever the engine is on. It only goes away on warmer days (70+) and has been the same for maybe three months now. It can be heard from inside and outside the vehicle, but it's quieter outside, but I can't pinpoint where it's coming from in my casual observations. (Under the hood, walk around, etc)
    The hum is not affected by:
    Speed - Happens at idle all the way up.
    Stopping, going - Only shutting off the engine quiets it.
    Interior fans - AC, Heat, on, off, high, low, all the same.
    I suspect it's something like a heat shield or other under body part thats next to something and is just touching or otherwise rubbing, but I'm not sure. Could be exhaust or the cat?
    Just wondering if anyone had any suggestions.
    Thanks,
    Carter.
    2017 Q5 - Premium Plus 2.0 - Lava Grey
    (departed) 2010 A4 - Premium - Ibis White
    (departed) 2004 A4 - Ocean Blue Pearl
    Dec 06 2007
    Re: Humming noise
    could be a VAC leak! also check ur Fuel Filter, it could be dirty!
    -Kirk
    BetaAlphaTau Member #58
    Senior Member Two Rings sailor's Avatar
    Feb 19 2008
    TBird.TC Miata A4Avant BMW.R80
    Blackhawk, CA
    Re: Humming noise
    Fuel pump maybe. I have a t-bird that has a noisy pump, been noisy for the last 80k.
    2003 A4 B6 Avant 1.8T Quattro Sport Tiptronic REVO
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Humming noise
    Maybe a fuel pump... try and pull up your rear seats and see if it gets louder.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Veteran Member Three Rings Carbon's Avatar
    May 24 2005
    2004 E46 M3
    San Diego, CA
    Re: Humming noise
    you should get the car on a lift and try to narrow it down to at least the front or rear of the car
    03 A4 - Sold
    Senior Member Three Rings AudiRob's Avatar
    Mar 10 2008
    06 Saab 93 Turbo / 02 B6 A4 MT / E55 AMG
    East Bay, NorCal
    Re: Humming noise
    if the sound is coming from the passenger side rear tire - then most likely its your fuel filter/pump. i replaced my fuel filter and it dissappeared.
    Apr 20 2004
    Portland, OR
    Re: Humming noise
    Thanks for the replies. The weather is getting warm here, so it may be awhile before I can pinpoint the issue. I'll keep and ear out!
