Results 1 to 6 of 6
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    Quattro + MisMatched Tires??
    I read somewhere that different sized tires on the front & back will mess up a quattro transmission... To what extent is this true?
    Will 255/35/ZR18 fronts & 255/40/ZR18 rears cause any problems?
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: Quattro + MisMatched Tires??
    255 are a no go on our cars to begin with.. 225/ 235 max.
    -18 718 GTS
    Senior Member One Ring
    Oct 07 2007
    Jacksonville, FL
    If I'm not mistaken, the different diameters would cause a difference in the revolutions between the front and rear axles. This difference would cause excessive wear on the center diff.
    That's my understanding of it at least.
    May 04 2008
    Columbia, SC
    Ahhh, now that I see a reason, it all makes sense...:D
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    That little aspect ratio difference results in a height difference of about an inch. That is a pretty big difference. A 255/40-18 is a tall tire compared to the 225/45-17 stock size or our standard fatty sizes of 235/40-17 (a little shorter) or 245/40-17 (almost dead on). A 255/40-17 is a little taller than stock and the equivalent of a 255/35-18.
    Jim
    I Do Werk.
    Senior Member Two Rings my 1.8t's Avatar
    May 04 2008
    tucson
    make shure that you rotate the front to back also because my understanding is that the tires need to wear the same or that can be an issue and if you had tires on there for a while and got a flat i was told that you need to buy all four tires or have that one shaved
