Results 1 to 7 of 7
    Veteran Member Three Rings audiwop's Avatar
    Dec 11 2006
    2007 Audi RS4, 2010 Ford SVT Raptor, Toyota Tundra, VW Treg,Ducati Hypermotard 1100S
    Orange County,CA
    Fuel Rail Emergency
    Installing stage III fueling. What is the trick for lifting the fuel rail? I am using AWE's directions for install and the fuel rail is not lifting up after everything is completely disconnected. Please Help! ASAP.
    Dec 11 2006
    Orange County,CA
    Re: Fuel Rail Emergency
    nevermind, haha
    Active Member Four Rings
    Jul 17 2004
    Quote Originally Posted by audiwop View Post
    nevermind, haha
    Lemme guess...you just gave it a firm pull?
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    lol
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Dec 11 2006
    Orange County,CA
    The firm pull wasn't working so we used a breaker bar on each side simultaneously... at that point it was cake!
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    So you're going with the AWE stuff huh? Did you ever get a hold of some IC's? Incidentally, AWE recommends the darin mod to the airbox. So, if you're doing the install now, you may want to take the airbox out and cut the hole at the bottom (assuming you haven't already). Once you're all done the hardest part comes...breaking in the clutch
    Dec 11 2006
    Orange County,CA
    ^^^ actually I went with VAST, I was just using AWE's directions for more of a road map on what to do. As far as the IC's go, I'm going to pick up a set of AWE's new batch this week.
