Results 1 to 28 of 28
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    CAR UPDATE: Mounting the ECU in its new location...
    First I use and aluminium sheet cut it down to fit the mounting area. Then II a right angle welded to the bottom of it. This right angle will be used to screw it to the tranny tunnel. I added industrial grade Velcro to it.
    I then installed Velcro to the back side of the ECU.
    The mounting plate was then secured in place by three metal screws on the top that screwed into the transversal steel beam. The bottom part of the mounting plate is secured by two metal screws through the tranny tunnel.
    Head on view of the mounting plate and ECU in place. Of course you won't really see this when the new centre console is installed.
    Veteran Member Four Rings DELUX's Avatar
    May 28 2004
    04 A4 USP 1.8TQ M6 Ultrasport
    Asheville, NC
    Re: CAR UPDATE: Mounting the ECU in its new location...
    Look at all that spaghetti!
    USP CLUB MEMBER #3 - 2004 Audi A4 1.8TQ6
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    Your car is so insanely baller its nuts! Love it!
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STĂSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Registered Member Two Rings
    Apr 15 2008
    Really Lost
    holy shit! can i say shit?
    there should have been a warning in the title - NSFW, or some warning there would be some graphic details... the third picture.... was not what I was expecting for a ecu re-location!
    good work! a man who is not your typical modder. You don't buy that as your local pepb0ys.
    Senior Member Two Rings has6's Avatar
    Aug 06 2007
    '21 SQ5 | '20 XC40
    Brooklyn, NY
    JJ should have his own TV-channel, anyone second this notion? lol
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    Jet,
    I hope you're not paying for that welding job..
    APR Tuned Serbia
    Authorized APR Distributor
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by zemun2 View Post
    Jet,
    You have not changed... I see always one to criticise.
    Feb 17 2005
    Sarasota, FL
    I wish mine would fit there! Less crap in the engine bay FTW! When you get to removing useless parts from the engine bay, then Ill be REALLY excited ... its my thing!
    Feb 20 2004
    Zemun, Serbia.
    Quote Originally Posted by Jet Jockey View Post
    It has nothing to do with me, but everything with the way welds look like. If its you welding/learning then its ok, but if you're paying someone to practice then thats something else..
    APR Tuned Serbia
    Jun 17 2004
    Montreal, Canada.
    Sure it does. I've known you for many years and you are one to criticise all the time.
    In any case I know it doesn't look good. The shop I'm using (2 minutes away) is not specialized in small pieces and in "refined" work (they work of heavy machinery) but I needed it fast. The same can be said about the framing of the centre console. In either cases it suites me for now and when I get a permanent centre console made it will be better.
    Also keep in mind it's 1/16 of an inch thick aluminium and that is very hard to weld properly without burning through it.
    Feb 20 2004
    Zemun, Serbia.
    Every time i see welds like that I sure do criticize..
    Forget about welds, how much does your car weigh now?
    APR Tuned Serbia
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Look, If youre going to be posting every week with something youre doing to your car and then complain if someone has something to say, I dont think you should be posting. This is the internet and people have opinions so no need to take things personally or be an ass about things
    Senior Member Three Rings Sleepy 1's Avatar
    Apr 03 2007
    B6A4, B5 Passat, my girls B7A4
    Always pioneering, everyone on this site knows who Jet Jockey is. Thanks for always keeping us updated. Whats next?
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by A4ringedONE8T View Post
    Well the complete AC system is coming out so is the secondary air pump system including the valve the vacuum hoses ect. The complete ABS system in being removed including the ABS pump and its controller, the master cylinder is also being removed. I may also remove the water/oil cooler from the car.
    I have already relocated the battery to the back and a CF hood is going on. This should save a lot of weight upfront.
    In the future the power steering pump may be removed too and replaced by an electric driven pump. I'd also like to find a smaller windshield washer tank.
    If you can think of anything else I should remove, please let me know.
    How's that for useless junk coming out from under the hood?!
    Jun 17 2004
    Montreal, Canada.
    I think you know that I know those welds aren't the prettiest so why bother especially when you know I don't buy or put shit on or in this car.
    In any case enough on those shitty welds. :-)
    As for its weight I'm not sure yet. It weighed 2979 lbs prior to the cage going in but lots of things have still to come out. I would like to target about 2800 lbs once all finished.
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by audipotential View Post
    Yes I know but it all depends from whom and how the criticism comes across.
    I'm up for any constructive criticisms but not just criticisms for the sake of it especially from guys that have been around these forums for as long as I have and know me and my car.
    Sep 24 2007
    Woodbridge, Ontario
    So youre saying hes grilling you basically...
    Feb 20 2004
    Zemun, Serbia.
    I'm not grilling him, just telling him that those welds look like rubbish and in no way I would accept that and pay for it.
    he can take it any way he wants but that ain't gonna make those welds look any cleaner.
    APR Tuned Serbia
    Veteran Member Three Rings Noodle's Avatar
    Oct 16 2007
    Pittsburgh, PA
    It's pretty clear he's not going for clean.
    Nov 13 2007
    02 A4 3.0QM, 84 Rabbit GTI
    Gaithersburg, MD
    So are you going to friction tape or split-loom all that wiring?
    Veteran Member Four Rings michgo's Avatar
    Oct 21 2007
    Wagon/Variant/Avant A4 B6
    I love these threads. Absolutely love them.
    I heart wagons.
    'It's actually a pretty big pet peeve of mine when people mess around with my photos', MmmBoost
    shave it mold it sand it paint it
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by Splattj View Post
    Both methods are used throughout the car.
    DUH! an Audi
    los angeles, CA
    what you doing to your car anyway?
    Veteran Member Three Rings AWDTurboLuvr's Avatar
    Apr 21 2004
    A4
    Vancouver
    He's making a show car.
    2003 A4 1.8T Quattro - [B5 S4 Brakes.SS lines.PBR pads] [SB OFE STG3 Clutch] [S4 RSB] [BBS CH 18"] [Falken 452] [CC MOD]
    2002 Mini Cooper S - RMW Tuned 191whp/168 lb-ft [Dinan S1] [JCW injectors] [JIC/Cross inverted coilovers] [TSW LCA] [Alta 15%] [GramLights Optomise57] [Dunlop Direzza Star Spec 215/45/17] [ProSport Boost Volt Gauge]
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    Quote Originally Posted by AWDTurboLuvr View Post
    ROFL
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Jet,
    That is too funny, the first thing I though was damn that weld sucks haha , I can't weld good so I can't talk but I have lots of friends who do so it just instantly stuck out. And yes 1/16" aluminum is hard to weld, a friend of mines dad welded a coke can one day, try that
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by A4 TSCHUSS View Post
    I agree 100% but for now it will have to do. Not this weekend put the next one I have a track date and I need to get some mechanical work done to the car first. This dash/electrical thing is taking way too much time.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    These threads excite me. More pics
    -Sami-
