Originally Posted by
JayyyyyC
Thanks for the info. OP, sorry for the hijack, but one more question. I talked to Vast and JHM and both know that I'm returning my brand new pre-cat o2 sensors I bought from Vast because I had found out that their software codes the o2 sensors out. So you're saying that they code the post-cats out?
If that is true, then shouldn't I keep my pre-cat sensors instead of returning them for a credit? Also, I purcahsed the SSAC turbo back exhaust, and as you may know, it doesn't come with a cat, and I don't plan on running any. How do our cars run healthy if those pre-cat o2 sensors are so vital?
The ECU needs an O2 sensor input for the passenger side and the driver side. The O2 sensor signals need to go into the pre-cat O2 sensor inputs in the ECU.
If you get software that removes the need to run post-cat O2 sensors, then you don't need them, otherwise you do.
If you will not have any cats in your car, then you can install the O2 sensors anywhere, as long as they plug into the pre-cat O2 sensor inputs in the ECU.
At full throttle the engine runs in open loop mode using the sensors in the engine to determine the air fuel ratio. At partial throttle the engine runs in closed loop mode using the sensors in the engine AND the O2 sensors to determine the air fuel ratio.
Post-cat O2 sensors are ONLY used to determine if the catalytic converter is working properly. Pre-cat O2 sensors are used to keep the air fuel ratio correct.
I would be VERY surprised if the VAST/JHM software removes the need for all four O2 sensors.
