Results 1 to 24 of 24
    Established Member Two Rings bbkid43's Avatar
    Sep 24 2006
    Minnetonka, MN
    Installing S4 sideskirts without the mounting brackets?
    Planning on buying some s4 sideskirts here soon but prices at my local audi dealer are way too high for everything. They quoted me over $630 for just the skirts and brackets unpainted!
    i've done plenty of searchin on the forums and have found some examples where people said they installed the skirts without the brackets. but i haven't found anything about whats needed to do this. im also planning on running without the door moldings so that wont be a problem.
    for the people that have put the skirts on without brackets, could you give me some tips on how to do it?
    Veteran Member Four Rings CaSp3r9's Avatar
    Nov 30 2005
    Tools and toys
    Los Angeles, CA
    Re: Installing S4 sideskirts without the mounting brackets?
    I did mine without the brackets. I pulled up the black plastic molding that sits on the car, inside the doors. They're held on there with heavy duty double-sided tape so it makes it a little easier if you have a hair dryer/heat gun handy to heat up the glue to remove it. When you get the plastic pieces off, remove the rest of the tape residue and lay down new strips of heavy duty double-sided tape leaving the top half of the tape still covered so you don't get anything on it. Make sure the inside of the skirts are very clean for a stronger hold. Get a friend to help you set them in place on either side. Don't forget to test fit both skirts before you adhere them and make a mental note of how they should sit. As for the bottom portion of the skirts that just kind of hang down, I drilled some holes underneath my car and used some half-inch long screws where necessary to get it to fit correctly.
    It's a simple but time consuming project and is definitely worth the effort in the end. Don't cut corners like I did my first time, take it slow and make sure everything fits well. If you have any questions, PM me. Good luck!
    1998.5 A4 1.8tqms, Sold
    2006 A4 2.0tqm
    I have a VAG-COM if anyone in the Santa Monica area needs it.
    Veteran Member Four Rings 1.8Titorey's Avatar
    Mar 04 2004
    97 A4
    Fremont ca
    ^^^I did everything he said except instead of using screws I used rivets
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Jim
    I Do Werk.
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    i used some industrial velcro to hold the top by the door sill
    the s4 rear mudflap bracket
    and screws and washers into the underbody
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Quote Originally Posted by 1.8Titorey View Post
    Quote Originally Posted by CaSp3r9 View Post
    Do either of you have pics of the install process?
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    i definately need this thread right now, i just wetsanded my s4 skirts today
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Do i need to take anythign off on the existing stock stuff before I do this?
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    I've got a pair of s4 skirts that are painted and collecting dust let me know how yours turns out!
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Jun 04 2007
    Austin/DFW, TX
    bumpp.
    im painting my skirts today
    My 5-Speed Swap DIY
    - B6 USP
    Jan 11 2007
    texas
    Keep me posted if you want i'd like to help/work with you installing yours so i'm ready to do mine.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Jun 04 2007
    Austin/DFW, TX
    just got these bitches out of the booth 15 minutes ago.
    Believe it or not, i used a generic black which matches perfectly and was used previously on my s4 bumper
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings brlukosk's Avatar
    Mar 21 2006
    St.C MN
    nice!
    I wish I could find a pair for cheap...
    Jun 04 2007
    Austin/DFW, TX
    Ok, im not too sure on how to install them.
    What is a ring clip?
    What do I do with the ends that connect to the door blades if I am going to use my stock ones?
    help? lol
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    what do i do about this for the stock molding?
    My 5-Speed Swap DIY
    - B6 USP
    Oct 06 2004
    Minnesota
    Quote Originally Posted by pacman View Post
    Screws in the underbody here too. Then some construction grade adhesive to hold it in place. I also molded them to my fenders
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Jun 04 2007
    Austin/DFW, TX
    what did yall do about those end pieces in my recent pic?
    My 5-Speed Swap DIY
    - B6 USP
    Nov 06 2006
    garage ornaments
    southeastern pa
    cut them off
    -Nic
    My Car
    Jun 04 2007
    Austin/DFW, TX
    anyone else cut theirs?
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings fikes's Avatar
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    The real way to do it is those clips are attached to the body then s4 door trim overtop of it as well as Velcro along the door sills. If you want to do it the shitty way cut them off then use 3m tape or Velcro to attach them and keep your a4 door trim.
    1997 Audi A4 Sedan 1.8t- Sold
    1999.5 Audi A4 Avant 1.8t- Sold
    2001 Audi S4 Sedan- Current
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    Quote Originally Posted by fikes View Post
    thats what i was thinking
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    Jun 04 2007
    Austin/DFW, TX
    just finished. Pics soon. Used bracket and Velcro,nothing else
    My 5-Speed Swap DIY
    - B6 USP
    May 31 2005
    Dallas
    pics asap lol lets see it man
    Oct 20 2007
    x2 on the pics
