Results 1 to 9 of 9
Thread: brake pad light
    Registered Member Four Rings cerfus's Avatar
    Oct 16 2007
    Germans
    Scottsdale
    brake pad light
    went on today, how much use do they have left?, because if I can I'd like to just order new drilled rotors and ceramic pads and do the install at the end of this month.
    and speaking of rotors, will I just use 288x25mm? and where can I get hooked up with a good deal. I was just going to go with Zimmerman cross drilled 288x25mm front rotors for 89.00$ but they website doesnt sell cross drilled rear rotors and I figured since I was changing the rotors/pads in the front I'd do the rear too.
    and If someone could hook me up with a DIY thread on how to do this on a 2.8 that would be awesome.
    thanks
    heres the site I was going with as well: http://www.purems.com/products/products.php/CA=1441
    ///Mcars
    looking for a sileighty..
    E39 M5 DD full Hamann exhaust h-back/ Hamann CF splitter/ Hamann C Diffuser/K&N intakes/ecu tune more to come.
    Keep your eyes peeled DG, CRFS coming your way!
    Oct 16 2007
    Germans
    Scottsdale
    Re: brake pad light
    bump, for i need your aid!
    ///Mcars
    Established Member Two Rings Digga's Avatar
    Jun 18 2007
    FL
    Re: brake pad light
    You should be fine for a little but they make those warning lights for a reason, so I would get on it if you are going to order online. I went a week or two last time and was fine.
    Current
    FOR SALE
    2013 BMW 335i M Sport
    MPE/Dinan springs/Rotiform
    http://f30.bimmerpost.com/forums/sho...d.php?t=998376
    Former
    04' A6 2.7T ~APR 93 OCT Tuned
    -APR R1 DV's, Eibach Sportlines, RS6 lip spoiler
    Oct 16 2007
    Germans
    Scottsdale
    Re: brake pad light
    ok I figured It would last a bit, im not even driving it until I fix those brakes, I guess I'll just have to put up with my M3 for a while...
    ///Mcars
    Veteran Member Three Rings Alpinevelo's Avatar
    Dec 28 2006
    06 VW Jetta I5 daily driver bone stock 4 now
    Fountain Hills, AZ
    Exclamation Re: brake pad light
    Quote Originally Posted by cerfus View Post
    thanks
    After the warning light comes on you have aproximately 1,000 miles or 30 days according to the dealer. In my case I went almost 60 days and by the time I actually changed the brakepads I had about 1 mm left of "pad" but the technician told me that it's not agood idea to let it go that long because at that stage large chunks of pad can start breaking off and you could find yourself in a tough spot if you have a tough situation.
    As for the DIY, I'd do the front and would leave the rears to a Pro, they are a beoch to do...
    C5 A6 2.7T GIAC software Stage 1, EVOMS DV Valves, Cupra spoiler lip, RS4 OEM 18" Wheels.
    Alex
    Oct 16 2007
    Germans
    Scottsdale
    Re: brake pad light
    yeah the fronts I was planning on doing my self, but I heard that the rears are just total bitches to get off.
    ///Mcars
    Senior Member Three Rings massboykie's Avatar
    Mar 14 2008
    '16 Audi S6, '16 Audi S5 Cab.
    Natick, MA
    Re: brake pad light
    Hey Cerfus
    I got mine from these guys http://www.designrt.net/rotor.htm . Good deals and good quality. My fronts were Zimmermans rears Ate. The rears are realy no harder to replace than the fronts. The "getting them off" part is the same on the fronts. The rotor is lose on the hub (front and rear), but the steel hub and the cast rotor sometime "rust together" which makes them hard to get off. I used a 4lbs hammer with a piece of harwood (soft metal punch would also do) and gave it a few good wacks on the hub face (inbetween the lug holes). If that doesn't work the wack the rotor surface. You are not re-using them so who cares, right? In the rear you also need to screw the caliper piston back in. There is a $10 cube you can buy front AutoZone or Advanced that you put on an extension and then push and rachet it back in.( http://www.etoolcart.com/browseprodu...-LIS28600.HTML ) There is a nice tool kit you can rent to do it also ( I got mine from Autozone). ( http://www.etoolcart.com/browseprodu...-ATD-7024.html ) Not dificult at all.
    In the front you'll also need a 7mm allen socket to remove the caliper, the rest is all regular sockets and wrenches. Oh and some brake lubricant (usually in little packets at the checkout counter) and some brake anti squeel.
    Hope that helps.
    Cheers
    Massboykie
    2016 Audi S5 Cab. - ECS Intake, K&N DI
    2016 Audi S6 - K&N DI, 10mm VCDS drop+12mm Spacers, Disc Italia+HPS 5.0
    Not to be forgotten...
    2016 Audi A3 2.0T, 2006 Audi A4 Avant 2.0T, 2002 Audi A6 2.7T, MKIV VR6 GTI & GLI, MKIII GLX & GL Jettas
    http://www.VAGLinks.com - 2000+ VAG Links!
    http://www.PlanetVAG.com - VAG Only Search Engine!
    Oct 16 2007
    Germans
    Scottsdale
    Re: brake pad light
    damn man! thanks for all that, it will help out big time for sure, that cars just been sitting in my garage for the past week now anyway, im planning on doing it either before I leave for germany or when i get back I'll keep you guys posted!
    ///Mcars
    Mar 14 2008
    Natick, MA
    Re: brake pad light
    Hey Cerfus
    Some more info if you are interested when I did mine....
    http://forums.vwvortex.com/zerothread?id=2995079
    http://forums.vwvortex.com/zerothread?id=2985563
    Cheers
    Massboykie
