    Sep 25 2006
    nj
    help me diagnose my clutch problem
    I have noticed when it gets hot out sometimes when I push the clutch down it doesn't come back up. Sometimes it will come up enough to shift gears, sometimes not at all. Usually the clutch grabs fine, as it has all winter. My only thoughts right now are to bleed the system, and if that doesn't work maybe master and slave cylinder. Any suggestions?
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Re: help me diagnose my clutch problem
    its the clutch system. there are 2 things i had to replace with thsi problem. first the little part under the clutch peddle, then the one on top of the tranny. i did it at seperate times, but they both failed right after each other. i was later told from a shop that you shoudl replace both together. if your peddle is getting stuck though, sounds like the it is most likely one of those cylinders
    and yeah, i wouldnt drive it like that unless you want to end up paying for towing and a fix
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Sep 25 2006
    nj
    did you have the same problem with the warm weather? what did the parts look like?
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    start with the slave cylinder, its cheaper.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by audiness View Post
    Neither are cheap.
    Bleed the system first, doing it the old school way with two people helps.
    You haven't removed the "helper spring" have you? I'd put it back in if you have. Reason I'd say bleed it first is that even with the helper spring in place, when you bleed the system, after opening the bleeder, the pedal will stick to the floor. Similar to your current problem.
    If there aren't any leaks, and the you're not low on fluid, I'd look into the flex hose that goes to the slave cylinder. It's possible that it's deteriorating internally. No promises, but a possibility. If it's been removed it could also be twisted to hell and acting up b/c of it.
    If you want a non-text book and non-forum friendly way to double check if you have air in the system, shoot me a PM. I learned this one by trying it when I was diagnosing my own issue w/ my clutch.
