Results 1 to 12 of 12
    Feb 17 2008
    Question Sunroof wont stay open and dr side window 1 touch wont work?
    This happens occasionally. I will open the sunroof up and it closes on its own. Also on occasion the drivers side 1 touch window button wont work and i'll have to hold the button to get the window up or down. Whats the problem?
    02 Audi A4 1.8T Dolphin Grey Pearl 5 speed Retro Solutions HID Podi boost gauge Stern snub
    92 Mustang LX 347 stroker
    Veteran Member Three Rings A4_Mike's Avatar
    Apr 09 2007
    2014%20Audi%20A4%2C%202017%20Audi%20Q5
    Cary%2C%20NC
    Re: Sunroof wont stay open and dr side window 1 touch wont work?
    Quote Originally Posted by Mike02A4 View Post
    Try this AudiWorld Tech Article. It worked for me.
    Best of luck!
    2014 Audi A4 2.0T quattro | Volcano Red | Chestnut Brown | Tip | P+ | Nav + | Sport | B&O
    2017 Audi Q5 2.0T quattro | Ibis White | Ebony | Tip | P
    Senior Member Two Rings treemolecule's Avatar
    Jan 13 2008
    04 1.8TQ6M(^^sleepy car)
    Charlotte, NC
    try re-setting your window. whichever window's one touch is messed up do this
    1) roll the window all the way up and hold for a second
    2) hit it UP once again for about 1 second
    done.
    depending on certain outside to inside air temp. our windows do funny things
    [B]APR Stage 1+ and Snub Mount
    034 DensoLine Engine and Tranny Mounts
    GReddy Turbo Timer
    Forge TIP (RED)
    Feb 17 2008
    Thanks i'll give them a try!
    Veteran Member Three Rings b6a4's Avatar
    Oct 09 2006
    Asheville, NC
    gotta love audi ownership..
    __________________________________________________ __________________________________________________ ____________________
    2001 Audi S4 Avant. Black/Blue Sport. SRM K24 Hybrids. (Totaled)
    2017 Audi Q7 3.0T
    2010 Audi Q7 TDI(sold)
    Feb 17 2008
    The window reset worked, thanks!
    I'll try the sunroof DIY when I get a chance.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    My sunroof switch needs to be de-greased also. I'll add it to the 20 others things I need to do to it.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    i did this once (sunroof fix) and it worked for a while (about a year). need to do it again as it's starting acting up.
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
    Registered Member Two Rings
    Jan 14 2008
    NEW YORK
    I had the same problem with my sunroof and since my car is certified I took it to the dealer. They ended up changing the switch because apparently it is known to go out. Usually its from dust build up. Well hope this helps..
    Veteran Member Four Rings golgo13's Avatar
    Apr 29 2007
    Tampa Bay
    when it is opened pull down on the switch and watch it close and dont let go until is fully closed. This solves the problem if it doesnt close. As far as not staying open try the cleaning thing I couldnt tell you Sorry
    SweetnLou!
    Established Member Two Rings keith's Avatar
    Jun 03 2007
    AUDI A4
    farmingdale, new york
    my sunroof has a mind of its own i have to close it like 3 clicks at a time not all at once and sometimes it just opens and closes for no reason who the hell knows
    Feb 17 2008
    Quote Originally Posted by keith View Post
    Gotta love technology
    My car is a CPO also, maybe i'll mention it when I take it in for 2 small coolant and oil leaks I have.
