Results 1 to 19 of 19
    Dec 17 2007
    MI
    Cluster Swap: S4 to 1.8tq
    Can you swap a 1.8tq cluster with a S4? Looking to buy.......
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: Cluster Swap: S4 to 1.8tq
    It depends on the year of your A4. Do you have a digital or analog clock?
    Jim
    I Do Werk.
    Dec 17 2007
    MI
    Digital clock. I have a 2000 A4 1.8tq with ATW engine Vin "C"
    Mar 09 2004
    nw michigan.
    Then they at least speak the same language. That will help. I still don't know how to complete the swap though.
    Jim
    I Do Werk.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I do not think so, i searched a little while back
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    I am pretty sure you can, you will have to recode the s4 cluster for a 4 cylinder if that is indeed what you have.
    Also the redline will be inaccurate but everything else should work, check audiworld for more info on this.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    you can. people do it all the time to all kinds of different audi's. not uncommon at all
    Quote Originally Posted by audinutt View Post
    -richard
    what does the redline and number of cylliders have to do with his guage cluster?
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jan 11 2007
    texas
    Quote Originally Posted by sean1.8t View Post
    The redline on the s4 is higher than the a4 and the tach will read different since the s4 has a 6 cylinder unless it's recode via a vagcom.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Sep 17 2006
    SLC, UT
    ^apparently im not getting it
    Current:
    Previous:
    Sep 17 2006
    SLC, UT
    unless im taking crazy pills right now....
    Current:
    Previous:
    Jan 11 2007
    texas
    As I recall the redline on a s4 is 7200, this was my concern and if it's not recoded for a 4 cylinder it will read low on his tach as well.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Sep 17 2006
    SLC, UT
    anyone want to set this strait?
    Current:
    Previous:
    97 A4 2.0TQM
    Rochester, NY
    yeah..you are :P
    You need to re-code the cluster with VAG-COM and tell it if it's a 4 cylinder or a 6 cylinder. I don't remember the reasoning behind it , but if you don't, your readings will be off...
    I know with my standalone ECU you need to tell it how many cylinders the car has so it outputs the correct signal.
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    I do know the rpm on an S4 is 7200 as I have been looking at these clusters as well. I have done research and found the same information that is being said here to be true. You will need a Vag-Com to change the reading from a 6 cyl. to a 4 cyl.
    I have wanted to go this route because my car now redlines at 7200rpm anyways because of the APR Stage III
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    also, the number of cyllinders will not matter either. the crank sensor reads how many times the CRANK spins. not how many times, all number of pistons rotate on their own
    I though one revolution would be one revolution... A turn is a turn... If one piston makes one full cycle of up and down, it would be the same as the crank making one full turn would it not? 1 RPM would be the motors 1st cyl going from DTC to DTC would it not?
    ΜΟΛΩΝ ΛΑΒΕ
    Jan 11 2007
    texas
    Quote Originally Posted by Ewok_Fetus View Post
    yes but the 6 cylinder clusters are different codings, dont ask me why but i know it's been an issue in the past.
    Thanks for backing me up Phil I knew i wasnt taking any crazy pills... well this week at least ;)
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Mar 04 2007
    nothing
    nowhere
    -richard
    Yes, I know... I was just stating to sean that a revolution was a revolution no matter how you look at it... In the older cars, you hook a tach up to the coil and when the coil fires, a signal is sent to the tach... You will have the coil firing less often with a 4 cyl than with a 6... I don't fell like explaining right now... But less frequncy means less average power which is what a tach is based off of...
    ΜΟΛΩΝ ΛΑΒΕ
    Oct 21 2006
    2014 Audi S4, 2003 Audi A4 Avant 1.8tqm
    Westminster, CA
    You should also change the soft coding to match your current cluster. Ross tech has a "how to" article for cluster swapping. So match the cylinder count and carry over your soft coding to the new cluster. There was even a section on rosstech to change the mileage to match, but i think it only works on clusters will really low miles.
    Jan 11 2007
    texas
    Yes when you say low miles, hey mean less than 100 km's or 62 miles. so if you've driven the car farther than that you are out of luck.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
