Results 1 to 6 of 6
Thread: Inlet question
    Established Member Two Rings jaredsogn's Avatar
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Inlet question
    Well, I am piecing together stuff for my stage 3 upgrade, and I am at the point of inlets. I have read that you can just cut the stock inlets and use silicon couplers for the K04's. I would rather not spend $600 on RS4 inlets. So those that have done this, please post some input or pics if you can. Also, what is the small hose that connects to the inlets for?
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Inlet question
    Check out GenerationJDm's inlets. They are much cheaper than rs4.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Dec 06 2007
    Calgary, AB, Canada
    Re: Inlet question
    If you end up needing some RS4's give me a call and I'll take care of you 1-403-690-7135
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Re: Inlet question
    Quote Originally Posted by RolledMySTi View Post
    Yeah, I saw those too. But I'm just wondering how many people have done this? Can it really limit flow that much since it is just on the intake side? I mean the only reason the RS4's are bigger is to mate up to the K04's. How much difference is there in ID of the stock inlets vs. RS4?
    Active Member Four Rings
    Jul 17 2004
    Re: Inlet question
    Quote Originally Posted by jaredsogn View Post
    Either way, they are still way cheaper than RS4's and they're made out of aluminum. Don't have anything to lose.
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Re: Inlet question
    Quote Originally Posted by lil' is 300 View Post
    Definately. If I don't mod the stockers, I will go that route most likely.
