Results 1 to 34 of 34
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    not sure why coolant temp is f-ed up..
    alright when car is sittin in traffic coolant temp is at normal temp...but when driving around it dips down to the cold side a notch and sometimes all the way to the C...does anyone know why this is??? i had my ac high pressure valve changed and my ac recharged and then this started to happen...not sure if its related or not...is this a minor issue or what?? should i not worry about it that much...i feel as in i should only worry if it dips over to the H..
    already swapped to a green temp sensor...and i get no fault codes or anything...
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Jun 14 2007
    2000 S4
    Connecticut
    Re: not sure why coolant temp is f-ed up..
    wasn't there a thread about this by you not long ago lol, i would try the t-stat, i still say thats the culprit it used to happen to me same thing before i got all of that changed when the engine was out
    Jan 21 2007
    01.5 Silver Avant
    dc
    thing is, isnt that a bitch to change out??? or is not...i heard its a pain in the ass...just wondering if i should worry about this or just let it go...what would the issues be??? and how hard is it to swap out...heard the whole front clip comes off..
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    T-Stat hands down. You need to remove the timing belt to get to it, so it can wait for you to do TB job. It doesn't hurt your car, as it still runs normally, it's just annoying. I have the same problem, just waiting to do the whole TB shabang.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Jan 21 2007
    01.5 Silver Avant
    dc
    ive already done the damn TB job....this is bs. should i just replace my coolant sensor and see if that might be the issue for some crazy reason?
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by casawhites4 View Post
    Well, I've replaced my coolant temp sensor 4 times and it didn't help.
    I heard though statistically 3 out of 5 temp sensors produced have a chance to be faulty from factory. It's a lot cheaper then T-Stat(job, T-Stat itself is cheap) hence I did it so many times, but unfortunately I have a faulty T-Stat.
    Jan 21 2007
    01.5 Silver Avant
    dc
    and it really doesnt change performance or anything, or realizability..how long have you been driving on it...and im guessin its like the dead pixels just annoying as hell...do i need to worry about an motor damage...
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    I've been driving with it for 10k miles, about 8 months. I've been told numerous times by MANY (reputable) individuals, it fails in 'open' so it doesn't damage anything and it just makes the gauge not work properly, but the engine is fine.
    Veteran Member Three Rings tbone5446's Avatar
    Nov 16 2006
    b5s4, 85 4runner T3/T4 turboed
    San Diego
    shit mine is the opposite, just starting to slide past the halfway mark.
    I did the TB and both water pumps 30,000 miles ago and put a new
    thermostat in when it was apart.
    Think this might be the temp sensor?
    the needle is going between 1 and 2 clicks past halfway
    Thanks
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by Rated S View Post
    Modern t-stats fail in the open position about 99.9% of the time.
    Have the t-stat stuck open won't cause immediate damage to your engine, but if it's not getting up to operating temp, then the moisture in the oil isn't evaporating off, and can cause corrosion on the engine internals over time. It definitely needs to be replaced, but it's not necessarily urgent.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by The_Jerbel View Post
    So then I just rebuild with forged internals?
    Sigh, guess I should do TB job sooner rather then later now. Where's my Stimulus money, damnit?
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by tbone5446 View Post
    Thanks
    It's VERY rare for a t-stat to fail closed and cause overheating. Check to make sure your fans are turning on when the car is up to operating temp. If that's not it, I would fear a faulty WP before a faulty t-stat. Which pump did you put in when you did the TB?
    A bad CTS usually causes erratic gauge movement and is typically extremely inconsistent.
    Nov 16 2006
    San Diego
    checked last night when it was up to temp and only one fan was working (passenger side)
    should they both be on?
    Thanks for your help
    Jun 14 2007
    2000 S4
    Connecticut
    well is it always happening or is your issue constant? like if you beat the hell out of the car in the summer there is a good chance that the needle will go past half for the water temps if you dont cool your car off before shutdown.
    Jan 21 2007
    01.5 Silver Avant
    dc
    so jerbel...what do you suggest, can i go about it for a few weeks...and just change my oil asap right now...to get some fresh oil in there...
    Nov 16 2006
    San Diego
    constant for the last week
    it was real hot here a week ago but now its 60s
    freaking oil temp is almost hitting 250 also.
    i just changed the oil, and the car is running great otherwise.
    I am throwing a code for a cat going bad but that shouldn't affect the heat
    of the oil or coolant.
    I am guessing its a fan, but all guesses are welcome
    Jun 14 2007
    2000 S4
    Connecticut
    if you go out at night on a calm drive, your oil temps shouldnt be hitting 250! that OR go over normal water temps
    Nov 16 2006
    San Diego
    yeah I am aware of that, hence the question of what it might be
    car doesnt get driven much at night, and what is a calm drive in an s4?
    Dec 06 2007
    Calgary, AB, Canada
    They should both be on. Your car will heat up naturally when sitting in traffic and not moving, both fans should be on in that scenario.
    Dec 06 2007
    Calgary, AB, Canada
    Yeah, that'll be fine. A few weeks won't hurt, especially if you throw some fresh oil in there now.
    Nov 16 2006
    San Diego
    right on
    so probably a bad fan or a bad switch
    would it be beneficial to go ahead and install a remote electric fan?
    Dec 06 2007
    Calgary, AB, Canada
    Yup, it would be a good time to replace the fan switch (if that's the problem, which it most likely is), and do the clutch-fan delete mod and replace it with an EFK (which I can get for you if you need it). Call me anytime you like, and I can help you out. 1-403-690-7135.
    Jan 21 2007
    01.5 Silver Avant
    dc
    i need to do the fog light mod so that i can have my efk turned on without my headlights on...any write up..or anything or is the audiworld one the best write up
    Dec 06 2007
    Calgary, AB, Canada
    The one on AW is the best one I know of.
    Jan 21 2007
    01.5 Silver Avant
    dc
    yeah, i think i find the control box, but dont know how to get it out or cant even really see it at all....any pictures or anything better then the one on AW
    Dec 06 2007
    Calgary, AB, Canada
    Sorry, can't help you out with fog light related stuff, we didn't get fogs in our S4's up here in Canada!
    Jan 21 2007
    01.5 Silver Avant
    dc
    haha, yeah i know that jerbel my bad, just talk to the mechanic he said its def my tstat, but i ordered green temp sensor and a low temp tstat...said its a bitch to change since its like doing a timing belt swap again...what should i do while hes doing this?? or what can i do???
    Dec 06 2007
    Calgary, AB, Canada
    I would get a regular temp t-stat, not a low temp.
    What do you mean "what should I do?" Do you mean what other parts should you replace? I would say the WP, the serp belt, serp tensioner pulley, and the TB, the tensioner roller and hydraulic tensioner, and the idler pulley, as well as phenolic intake spacers (it's a good time to pop off the throttle body and the intake mani).
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    if your engine isn't reaching the ideal operating temp's, you're losing efficiency
    My car is fast
    Jan 21 2007
    01.5 Silver Avant
    dc
    already swapped out my TB and water pump..i got all new pulleys from ecs...and i have an efk...but lookin as in intake spacers heat wrapping..whatelse....already got a 034 snub, lightweight pulleys..new TB and water pump...
    Jan 21 2007
    01.5 Silver Avant
    dc
    why not a low temp one..i thought that would be beneficial for the summer and what not...dont see any harm in runnin a low temp tstat at all actually..
    Veteran Member Four Rings damnthemansam's Avatar
    Sep 20 2006
    motorcycles, boats, other cars and a longboard
    san jose, ca
    if the heat works good than its not the t-stat, i doubt it is, my moms a4 used to sit on C and we couldnt figure out why.. but the oil temp was normal and i dont think the oil temp could get to 200 degrees if the block was less than 100 degrees.. i think its in the gauge or something electrical
    Sep 20 2006
    san jose, ca
    because your car was designed to run at a certain temperature and if its not there its going to try to get there by dumping fuel, i dont know if it will if the t-stat is only 5-10 degrees cooler but i wouldnt bother
    Dec 06 2007
    Calgary, AB, Canada
    I responded on AW. The engine will be slightly less efficient if it's running cooler than it was designed to. Also running it at the temp it was designed to run at ensures that the temperature is high enough to burn out any impurities and moisture.
    Regarding parts: If you have already replaced all that crap then I would look at getting the phenolic intake mani spacer. That's about it.
