Results 1 to 13 of 13
Thread: Tire Size...
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    Tire Size...
    What's size tires do I need on 17" wheels? Will 225/55/17 fit?
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Senior Member Two Rings TheReflex79's Avatar
    Oct 08 2007
    1998 Audi A4 2.8Q, '04 Nissan XTerra
    Alexandria, VA
    Re: Tire Size...
    What kind of wheel and how wide is it????
    May 04 2008
    Columbia, SC
    Re: Tire Size...
    17x7.5 with 46mm offset
    Oct 08 2007
    Alexandria, VA
    Re: Tire Size...
    Any pictures? If they are the similar to a OEM TT fat five rim, tires size is generally 225/45/R17
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: Tire Size...
    I fit 235/35/17's on my B6 sport wheels and they ended up rubbing... So I got spacers...
    ΜΟΛΩΝ ΛΑΒΕ
    May 04 2008
    Columbia, SC
    Re: Tire Size...
    Oct 08 2007
    Alexandria, VA
    Re: Tire Size...
    Quote Originally Posted by nrowensby View Post
    Ok, I work for Mercedes, and those are the YAD rims for CL-Class, tire size on a MB would be 225/55/R17.....but I would probably go with 225/45/R17
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Tire Size...
    whether it's a 235 or a 225 your overall tire diameter should be ~24.9-25"
    225/45R17 or a 235/40R17 are common.
    Oct 08 2007
    Alexandria, VA
    Re: Tire Size...
    Quote Originally Posted by djwimbo View Post
    Excellent resource: http://www.miata.net/garage/tirecalc.html
    May 04 2008
    Columbia, SC
    Re: Tire Size...
    Yeah... I found a set fairly cheap with brand new 225/55/17's on them, I was wondering if they would fit my a4 with the tires that are on them now.
    Oct 08 2007
    Alexandria, VA
    Re: Tire Size...
    Your best bet would be to try that link that posted, input your current tire size, then input the size if the tires that you found, and just see what the difference is....if it isn't that drastic, you should be fine.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: Tire Size...
    That is a big difference of about 2" in height. I put one of the 225/50-17 up against my Audi and it was a bigger difference than I would have thought. It was about an inch taller and wouldn't have fit with any lowering. I run a 245/40-17 on 17x8 with no problems.
    Jim
    I Do Werk.
    May 04 2008
    Columbia, SC
    Re: Tire Size...
    That's what I figured... Sucks
