Results 1 to 13 of 13
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Think I can paint my wheels with tires on it?
    As long as I mask the tires and get around the lip really good, do you think I could paint them? I don't want to have any problems later on with it chipping and peeling... But I really should sand down the scuffs (just paint not metal) and what not... Make the paint stick better... Any tips? Should I put a clear coat on it? Going flat black...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Re: Think I can paint my wheels with tires on it?
    Use index cards and line them between the tire and the wheel
    Veteran Member Three Rings Mister2's Avatar
    Jun 30 2007
    Virginia Beach
    ^ What he said, its been done many times.
    I would go a step further and cover the tires behind the cards with some newspaper.
    99.5 A4 1.8TQM
    APR Boost Guage - Forge 007 DV - Techtonics 2.5" Exhaust - 17" RS4 Rep's - Debadged - APR 91/100 - 034 Motorsport 3" Test Pipe
    Working my way towards a BAT
    Ich liebe mein Audi
    "...oh so you got VTEC huh? That's cute, so does my girlfriends car." - Me
    Registered Member Two Rings
    Nov 01 2004
    90 Celica All-Trac, 01 A4 1.8T
    Bothell, WA
    Another for the index cards. Just buy a big pack and make sure you can have them overlap so you don't hit the tires.
    Roger
    90 Celica All-Trac
    01 B5 1.8TQ
    Mar 07 2008
    00 imola, sleeper subaru
    nj
    I did mine off of the tires, but flat black w/ a clear coat looks pretty cool.
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Quote Originally Posted by 2fast4me View Post
    Pictures? I would love to see this, I have been thinking about paining my 18" BBS RC's flat black or a gun metal.
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    You could always let the air out of the tire and paint them and then just air it back up. As long as you mark the tire before hand and make sure it doesn't move the balancing should be the same. Do you have a compressor or do you plan on using aerosol cans? If not you can rent one as it will give you a better finish with less wet sanding, and you can use it to air up the tires as well.
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    ^^^ Took the words right out of my mouth. Letting the air out lets you get more of the bead which will help make it look like the whole rim is painted and not just the face. It wouldn't be very pretty to have a black wheel with a sliver or bright silver around the lip's edge.
    Prep depends on what you're doing and how you want it to turn out. For a full-on paint job you should sand with 80 grit to get the imperfections out and scuff the primer. Then spray a coat of primer or high quality wheel paint. Then wetsand, clear coat, wetsand, etc. as needed. Or you could just hit thme with 80-120 grit and spray with a few coats of Plasti-Dip spray which is what I almost did to my stock Swings over the winter.
    Jim
    I Do Werk.
    Mar 04 2007
    nothing
    nowhere
    Well, I did this before but without the tires mounted. The paint I might be using is the BBQ grill black paint... It comes out looking VERY nice... Very sturdy and no need for wet sanding... Just need to sand to get the imperfections out of the surface.
    ΜΟΛΩΝ ΛΑΒΕ
    Jan 21 2005
    sf bay area
    wurth makes a very good quality aerosol wheel paint in a few standard colors, as well as a clearcoat for wheels. not cheap but about as good as aerosol gets. i used their silver and clear on a set of wheels with good results.
    Forum Moderator Four Rings docurley's Avatar
    UK London
    I did mine with tape and paper.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    did tape and paper too. worked fine.
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Mar 04 2007
    nothing
    nowhere
    I guess I will try the tape and paper method... Thing is, the tires have the thicker sidewall to protect the wheel lip, plus they are B6 sports which have no lip... So they are sunk in pretty good... I will see what I can do though! Like I said, the BBQ paint is rock solid when it cures... So I don't really see any problems...
    ΜΟΛΩΝ ΛΑΒΕ
