Results 1 to 6 of 6
    Apr 10 2008
    whats the easiest way to relocate the battery to the trunk?
    hey guys im new to this site, i want to shave some weight of the front of the car and was thinking to relocating the battery to the trunk. whats the easiest way do i need to put a hole thru the firewall and run the cables under the carpet or there is another way. also what kind of cables should i use and what gage? any help is appreciated. thanx in advance Bler
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Re: whats the easiest way to relocate the battery to the trunk?
    I wanted to do the same thing and it has been done before. However, I decided to make my life a hell of a lot easier by buying a PC680 (oddessey) which weighs 14 lbs and put it into the stock location. I used the stock battery strap and modified it. I lost a little over 20 lbs in the front and have not had a problem with it yet even as a DD in Wisconsin. It also only took a few minutes.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Established Member Two Rings dc878mmm's Avatar
    Jun 20 2007
    San Francisco
    Quote Originally Posted by s vier View Post
    How long have you had the Oddesey and have you ever left the lights on or had the radio on with the engine off?
    2001.5 B5 S4 Stage 3
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by NoLeafClover View Post
    You should never run any cables connected to the battery for any reason in the cabin. All that should go underneath the car. That includes sub wires.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Apr 10 2008
    thats smart, also u dont loose any trunk space. i might just do that
    thanx for ur help guys
    Apr 10 2008
    Quote Originally Posted by Rated S View Post
    i c ur point man thanx
    i like this site better than vwvortex
