Results 1 to 13 of 13
    Senior Member Two Rings Luca12's Avatar
    Sep 16 2007
    00 b5 s4
    jacksonville, fl
    pressure control valve?
    is that the 249 valve or the n75?
    Jun 14 2007
    2000 S4
    Connecticut
    Re: pressure control valve?
    n75 is the boost regulator i can tell you that, the N249 is for "divert air valve for turbo" and the one you mentioned the Charge pressure sender is G31, it sits on top of your TBB from the bipipe.
    Sep 16 2007
    00 b5 s4
    jacksonville, fl
    Whatever valve im talking about opens 10.2% as soon as i get on the throttle and lets all the boost out. I pull two codes, boost pressure control valve open, and charge pressure negative diviation.
    Jun 14 2007
    2000 S4
    Connecticut
    sounds like an N75 if its boost related, maybe someone near you can swap N75's and see if that does the trick
    Dec 06 2007
    Calgary, AB, Canada
    Could be either valve, post the actual code it pulled up, with the number.
    Senior Member Two Rings my01s4's Avatar
    Mar 06 2007
    Des Plaines IL
    sounds like a boost leak actually.
    01.5 S4 Black Avant (6MT)K04's:AWE GIAC 3:APR BiPipe:UUC VM3:Forge 007's
    (R.I.P.)
    00 Black S4 (6MT)K04's:AWE GIAC 3:APR BiPipe:UUC VM3:Forge 007's:DTS:STaSIS TrackSports 600/700:Sport Package:JHM SS:RS4 Knob:
    2001 Audi S4, Nogaro(TiP), Giac X 93
    Dec 06 2007
    Calgary, AB, Canada
    Yeah, it's possible, but he does have a valve problem for sure. Here's the clue: "boost pressure control valve open"
    Sep 16 2007
    00 b5 s4
    jacksonville, fl
    ya i dont think its a boost leak b/c when its cold it builds boost then drops off at high rpm's.
    Sep 16 2007
    00 b5 s4
    jacksonville, fl
    ok here the actual codes:
    17956 p1548 boost pressure contr. valve, open.
    17964 p1556 charge pressure contr., negative deviation.
    Jun 14 2007
    2000 S4
    Connecticut
    i would say N75 but wait for Jerbel to answer lol he knows ALL. if it was a boost leak more than likely it would say POSITIVE deviation since their is more air than usual
    Sep 16 2007
    00 b5 s4
    jacksonville, fl
    Thats what i think it is but wanted to check with you guys.
    Dec 06 2007
    Calgary, AB, Canada
    Yeah, the code you are throwing means your N75 is done, or the wiring to the N75 has a short somewhere. Try replacing the N75 and see if the code comes back after clearing it.
    Also, a boost leak typically gives you a negative deviation code, not positive deviation.
    Sep 16 2007
    00 b5 s4
    jacksonville, fl
    ok will do, thanks for your help everyone.
