Results 1 to 8 of 8
Thread: Brake Grinding
    Senior Member Two Rings bklein8888's Avatar
    Nov 08 2006
    '06 Dolphin Grey S4
    SF
    Brake Grinding
    Here's the deal...I have a 2006 with ~14k in the odometer. When i come to a stop from 25 MPH and below...the brakes squeal and grind pretty bad...what gives? I have been told by the dealer that I need to get up to like 100 on the freeway late at night (when no one is out) and more or less put the brake pedal to the floor to burn off the "buildup". Its extremely irritating and embarrassing when I pull up to a stop light and my brakes sound like those of a $2000 car...
    2006 Dolphin Grey S4 MT6
    35% Tint All Around
    Hoen Xenonmatch
    S4 Caliper Springs
    Corsa CB
    K&N Drop-In
    Senior Member Two Rings g_svan's Avatar
    Jul 25 2007
    -01 RS4, -85 90qt(981whp), -19 RAM 1500
    Sweden
    Re: Brake Grinding
    That's not unheard of :)
    I had an -02 S6 with the same problem... You need to clean the breaks better! Get in there with a high pressure washer nosle, and try clean around the pads. It kept the squeaking away for about a week...
    Or else you could just switch pads, to perhaps Hawk Ceramic's or similar...
    God luck!
    /g_svan
    Nov 08 2006
    '06 Dolphin Grey S4
    SF
    Re: Brake Grinding
    Thanks for the suggestion...would brake cleaner work as well? Could it be that I need new pads? How long do OEM pads last? Would this be considered something that the audi maintenance program includes? Thanks in advance!
    35% Tint All Around
    Hoen Xenonmatch
    S4 Caliper Springs
    Corsa CB
    K&N Drop-In
    Veteran Member Four Rings 10MPG's Avatar
    Oct 25 2006
    Current:
    Bay Area CA
    Re: Brake Grinding
    I had the same problem and I remember quite a few others on the forum does as well.
    I did a few of the "pad resurfacing" run and stop drill and it did help for a while but it eventually comes back.
    New pads should help - or do what I did and use it as an excuse to get a set of BBK
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Re: Brake Grinding
    Quote Originally Posted by bklein8888 View Post
    If I'm not mistaken (it's been awhile), Audi covers brake pads under normal maintenance up to 25K for one change. Check with the dealer before you spend any $$
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    Re: Brake Grinding
    A bit off topic, but we complained about brake squeal on our IS and Lexus ended up replacing the pads for free (there's more to the story, but the moral is...Go Lexus Service!!!).
    Cool stuff with a little growl!
    Nov 08 2006
    '06 Dolphin Grey S4
    SF
    Re: Brake Grinding
    Quote Originally Posted by Dodge2Dub View Post
    Good to know! I'll head to the dealer soon and get to the bottom of this! I'll keep everyone posted on this!
    35% Tint All Around
    Hoen Xenonmatch
    S4 Caliper Springs
    Corsa CB
    K&N Drop-In
    Nov 20 2007
    Montreal, Quebec
    Re: Brake Grinding
    Try putting a big blob of anti squeal behind your pads...my friend had a horrible squealing problem in his subaru until he went liberal with the anti squeal and his car sounds fine now. :D
