Results 1 to 6 of 6
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Vancouver stealerships...which one???
    I've already done a search so I just need confirmation. My new-to-me A4 is modded and will require service soon. It's got APR, Carbonio and exhaust, not to mention visual clues like tint and lowered on coils. It looks like in addition to the 55km service I'll also need the PCV valve done and would like to have the brake fluid changed with racing fluid. Should I take the car to Capilano or Richmond? Anyone in particular I should ask for? I'm very picky and want someone who knows what they're doing, both at the service desk and working on the car. I think Open Road is out of the question at this point.
    Also, do I need to swap out the Carbonio before I take it in or is that on the safe list?
    Black B7 Titanium - Sold
    APR93 | Carbonio | Vogtlands | RS4 sway | Abt quad-tip | Podi | BBS RCs w/RT-615s | RS6s w/W300s
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Eh?
    Re: Vancouver stealerships...which one???
    Capilano Audi is more mod-friendly. If you would like to have any warranty work done, it is always wise to revert your car to bone stock. You might be able to get away with your APR chip by using the stock mode if you have it. Audi of Richmond does not tolerate any mods, even minor ones like boost gauge, but Norman is cool to deal with.
    BTW, how do you like your ABT exhaust?
    Dec 26 2007
    PNWR
    Thanks for the heads up. Anyone specifically I should speak with at Cap? I guess I have to swap the intake huh? Will they give me a hard time with the exhaust?
    The Abt exhaust looks awesome and I love the note. My only complaint is that it's an axleback and that it's a tad too quiet, though I rather have it be too quiet than too loud. Both of this issues will be fixed soon when I turn it into a catback with a flowthrough resonator and larger piping.
    Please keep the comments coming...
    Dec 26 2007
    PNWR
    Two days, 61 views and one comment??? Does no one have experience or opinions about Vancouver Audi dealers?
    Senior Member Three Rings archimense's Avatar
    Jan 16 2006
    Vancouver, Canada
    I didn't have any problems with my mods when getting warranty stuff done at Audi of Richmond.
    Basically they told me, if you mod the suspension, suspension is no longer covered under warranty, etc. They replaced my wheels bearings under warranty even though I was lowered, had upgraded sway bars, etc.
    They also replaced my turbos under warranty even though I had a boost gauge and exhaust. They told me that a chip, or downpipes would void the turbo warranty though.
    Norman is the guy to deal with.
    2001.5 Audi S4 stg 3
    K04s, 85mm MAF, 60lb injectors, custom software
    ASP DTS/Tru-Dual/Downpipes
    Stasis Tracksports/4:1 Centre Diff
    Neuspeed 19mm rear sway - CPP rear end links/tie rod ends/front upper control arms
    VAST ceramic clutch, RS4 pressure plate, JHM shifter
    RS4 engine/trans mounts, Stern rear diff/snub mounts 55 watt HIDs, Odyssey PC680 battery, Innovate Wideband
    Dec 26 2007
    PNWR
    That's excellent feedback and the kind of info I was hoping to get, thanks very much. Anyone else? Anyone with experience at Capilano?
