Results 1 to 9 of 9
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    door sensor help
    Ok so my car was fine today (morning and afternoon) and this evening I get inside and close my door and the screen in the dash is saying my door is still open (drivers side only)when its slammed shut. It does go away most of the timewhen I pull the door handle towards me with force. Is this the door sensor? And how hard is it to fix? The open door noise is annoying the shit of out me.
    Nov 07 2007
    New York City
    Re: door sensor help
    can someone please give me some advice what to check for
    Nov 07 2007
    New York City
    BTW my car is sitting in the garage now an the car is locked, and the alarm is going off and on for no reason ever once in a while =(
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I had a few problems in theh past with my drivers door sensor doing the same thing.
    I think its an electrical connection that completes the circuit when you shut the door to shut off the stupid chime. take some rag or sandpaper depending on what kind of erossion is between the latch on the door and the door post and make sure its clean. This way it gets a good connection. thats how i got miine to work.
    if your alarm is going off, it may also be a short in the wiring in the door. often times from the door opening and closing all the time the wires that go from the door to the car get brittle and will break.
    One final thing you could try is unplug the connection for the drivers door, when doing this it will be as if the door is closed all the time and your inside lights wont come on when opening the door. kind of a pain, but it wont chime all the time while your driving. this is what I actually have for my front passenger door, all the other doors are working. to unplug this its located by the front passenger side kick pannel. pull the carpet up and you will see a bunch connections. you will just have to try unplugging each one until you see that its the one for the drivers door.
    Hope that helps.
    Scott
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Dec 06 2007
    Calgary, AB, Canada
    The alarm is probably going off because the car thinks the door is open...
    Registered Member Two Rings
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    For the last year I've had to keep my driver side door out of the sun/heat. I started having the same problem (except the alarm problem) and I figured out that if I keep the drivers door cool, the sensor works properly. But it's pretty much 10 out of 10 times when I park drivers side in the sun/heat, it thinks my drivers door is still open.
    ++You can use the screen display toggle button (the one that cycles through the Dash displays) to switch to normal display mode and off the door diagram.
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Quote Originally Posted by The_Jerbel View Post
    I can see what you mean, but for my S4 the alarm wont set unless all the doors are closed. if one door is open the door will lock, but the alarm wont beep until the door closes, so I still think there may be a short or something.
    Dec 06 2007
    Calgary, AB, Canada
    Well there is obviously a bad connection in the door sensor circuit. This could be an intermittent problem, so that when the circuit closes, the alarm arms. The the circuit opens again and the alarm goes off...
    Nov 07 2007
    New York City
    thanks I think its a short to. i will do what gointoscott said and clean between the latch on the door and see what happens. Thanks for the help everyone =)
