Results 1 to 29 of 29
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    CAR UPDATE: Centre console design, fabrication and installation...
    First of all let me say this is what I would consider a semi permanent installation. I would like when there is time available and funds to get a better centre console designed and made that would look some what more professional. However I'm out of time and I need to get this car running and on the road ASAP.
    Because we took the OEM centre console out I came up with this design. It's simple, light and fairly cheap to implement. I used an aluminium right angle 1/16 inch thick by ¾ of an inch by ¾ of an inch to make its frame. After the shape was basically tested in place it was welded together. Then for a face plate I used a plastic material 1/8 of an inch thick. The whole thing is screwed together and bolted to the car with some OEM attachment points and some I made.
    Front shot of the basic frame.
    Side shot of the basic frame.
    The first OEM attachment point. Located just ahead of the shifter.
    Top view. Frame in place.
    Side view of the frame in place.
    The second OEM attachment point that is also used to secure the OEM dash in place.
    Side view on the new console with its plastic face plate on.
    Reverse angle.
    Centre console's face plate with some of the buttons, controls, switches and electrical fuses in place.
    Close up of the face plate. As you can see I decided to go with a "Start Button" in blue. Why blue? Because I wanted to differentiate between it and the red emergency fire extinguisher discharge button. BTW It's not an OEM Audi start button because I inquired and it's $299! LOL. The Honda S2000's button is close to $100! I decide to put all relative fuses above the individual systems for easy access. Also the fuel pump switch is a very special one. It comes out of a Challenger jet aircraft and I don't even want to know how much it cost! My guess knowing aviation ~$1500! The reason for choosing it is simple. You have to physically pull the switch lever out, go over a detent and down into a position (whether ON or OFF). No one can mistakenly select it or deselect it. Two normal toggle switches run the car's lights and the rear defogger. Next is a dimmer switch for the LEDs and perhaps others lights to come. Next is a four position fan switch. Off, low, medium and high. The row terminates with the emergency fire extinguisher discharge switch. The arming/test switch is located somewhere else (yet to be determined). Below this row we have a 12 volt outlet and the hazard switch. Below those two is the OBD II port. There is a lot of room yet to add things but most likely that would be for other fuses for some other part of the electrical system.
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Re: CAR UPDATE: Centre console design, fabrication and installation...
    that looks great!
    the homebrew'd s4
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    hahahhooowwww my goooooood... i love the oem hazard button on there hah
    cant wait till ure finished with it... i've been reading ur "lightweight" project since day 1 on this forum, and so much time after ure still going... incredible :) mad props to you!
    Dec 06 2007
    Ur Crazy man!!!!!!!! that looks off the hook!
    -Kirk
    BetaAlphaTau Member #58
    Feb 17 2005
    Sarasota, FL
    haha nice!! Race car with daily driver abilities!
    Veteran Member Four Rings HeHateMe's Avatar
    Apr 05 2005
    lost wages, nv
    Quote Originally Posted by AudiA4Turbo22 View Post
    +1
    that thing will be able to run in Le Mans when you're through.
    <old school>
    --giacfxk03-siemensinjectors-milltekexhaust-ofestage4clutch-eibachprokit-stratmosphereshortshift--
    abracadabra homes http://www.audizine.com/gallery/data...une_06_142.jpg
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    Wait you gutted a luxury car to put in that?
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Dec 06 2007
    ^^ he wants to make it as light as possible!!!! i think he'll be doin great around a track when he's done, but i would never go this far!!!
    -Kirk
    Senior Member Two Rings abradley's Avatar
    Mar 12 2007
    02 A4 3.0 Quattro
    Virginia Beach
    looks like apollo 13 haha. props for being unique. cant wait to see the final project
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    unbelievable work, good job
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Orange County, CA
    youre insane. I love it. I cant wait to see this when its done.
    B5 Parts For Sale
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by OverSpun View Post
    Everytime I see your Avatar, I cant help but laugh! the "cock-o-meter" lol
    Sep 02 2005
    Montreal
    That looks... functional.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Now you need a matching steering wheel!
    Jun 30 2007
    Raleigh, NC
    lol, trans-am ftw.
    (that is a knight-rider replica, right?)
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Established Member Two Rings Jimbobdaga's Avatar
    Mar 11 2008
    Leominster, MA
    all the wires make my head hurt lol
    NOW: 2012 A4 2.0t | Black on Black | stock for now .. more to come :)
    PAST: 2004 A4 1.8t | Black on Black | APR Stage 1+ | Audi Sport Suspension| Neuspeed Exhaust | Ecode Headlights | Forge DV
    Jun 30 2007
    Raleigh, NC
    btw -- how much less does this weigh than the original center console?
    and i sent you a PM, got a couple questions..
    The Awesome™
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    crazy
    Some fast things and some slow things
    ~Josh~
    Veteran Member Three Rings ThatGuyAlex's Avatar
    Jan 24 2008
    NorCal BayArea
    Ecusssssseeee me sir. But where are the heated seats, and heater and stereo. whats this racecar busyness. lol
    thats looks good. More pictures of the car please.
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    It's beginning to look like the planes you fly This has been a long project for you. Have any idea when it will be done? Can't wait to see what that thing weighs in at...
    Veteran Member Four Rings BoostedA4tQ's Avatar
    May 24 2004
    Miami
    WoW Jet....Your still at it...long time no talk glad to see all the progress the car has gotten. Im in the works right now of getting myself back into a B6 this time im going manual hope to be sharing with you soon.
    Fernando
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    thats just insane... props to you for the big balls...
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    I get those from ADI for fire panels for $.99
    APR Tuned Serbia
    Authorized APR Distributor
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    It reminds me of...
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Registered Member Three Rings 8E1POINT8's Avatar
    Sep 26 2006
    Pittsburgh, PA
    Mad scientist is at it again. Good luck with the rest, looks good so far.
    Pete
    -04 1.8TQ-
    APR Stage 1+(93 & 100)--TT225 Injectors--K&N--710n--BKR6E--T.P.--Autometer--S4 Blades--LaminX--CC--Kamei--Ace Zeus 18x8.5--Toyo--Kenwood PNAV DDX-6019--Lip Spoiler--20% 3M--All kinds of black shit--
    Veteran Member Four Rings aaron1085's Avatar
    Jul 12 2007
    2007 2.0T A4
    NH
    let see more pics of the car... killer racer style you got there
    Dec 06 2007
    i'm sure gutting this thing out and making parts as such for it, cost more than the value of the car!
    -Kirk
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    any one know if a B7 tip center console will fit in a B6 so that I can get the cup holders next to the e brake?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Badass!
    -Sami-
