Results 1 to 4 of 4
    Veteran Member Four Rings redline_redline's Avatar
    Dec 18 2006
    Vienna, VA
    Pulling out the USP corner grills for bumper removal help! =/
    Ok search did me no good. I am finally retrofitting a center grill for my diy usp front. For some reason my grills wont come out! hah, i dont wanna pull too hard or move them around too much and scratch up the paint, so heres my question:
    Is there a form to pull out the corner grills on a USP front? I feel like such a noob now cause this is the dumbest thing to get stuck on. (and what i mean is i.e. pull up and out, or push in and lift out etc.) hopefully you get what i mean.
    So a quick answer would be great so i can continue this and post up some pics of the finished product. Thanks.
    2012 Phantom Black S4 ~ RS4 Grille ~ 19x9.5 ET45 Gunmetal V710s w/ MPSS 255/35/19 ~ Magma Red Silk Nappa ~ Carbon Atlas Trim ~ Alu Optics
    Gone: 2002 Denim Pearl Blue A4 ~ GIAC FX-K03 Stage 1+ ~ Genesis 380cc ~ Retrofitted USP front with custom mesh grills ~ S4 Rear ~ ACE 18" Hyperblack RS4s ~ Custom Magnaflow w/14851s ~ Hyperboost Compact ~ BoostedTech ~ RS4 Rear Sway ~ FK Housings ~ LED tails ~ M3 Lip Spoiler ~ SPP Yellow Fogs ~ 20% Tint
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    Re: Pulling out the USP corner grills for bumper removal help! =/
    honestly dnt be scared.. just poull on it
    it comes right out.. grab by the foglight holes and kind yank it out.. but like slowly with ur finger or flathead.. kinda wiggle where the clips are.
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    Just pulling on it will break the clips. There are little tabs exposed for most of the clips that you have to pull back towards the front of the car to release the clips. I usually have to stick my fingers through the grills and pull on those tabs. Good Luck.
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Just put your fingers through the grills and sqeeze as much as you can and then give it a quick sharp tug....it will come out
    -Sami-
