2000 GTI VR6 115k Only 499 others like it!
Engine/ DriveTrain/ Suspension
OEm Clutch at 95k with resurface flywheel
New water pump at 75k and checked at 100k
New thermostat
New CTS
New radiator
Bfi Driver side motor mount stg 1
Bfi trans mount stg 2
New OEM Passenger side mount
All tie rods done at 100k
Koni coil overs
DG skid plate
Raxel Half shafts
2.5 inch custom magnaflow catback exhaust with single R32 Tip
TT short throw shifter
Shaved intake box with 3 inch snorkel to lower grill
New brake pads all around
Every 5000 miles oil change with Mobil 1
Interior/ Exterior
Black Suede Headliner with matching shift boot
TT pedals
VW Ipod Integration
Sirius satellite radio installed where Change cup used to be.
Wired dual rear fog lights , Need Euro switch bc I bought a cheap one and broke it!
42 Draft Design Interior led light kit, License plate Led light, Led city lights
Amber H3 fog lights
Sylvania Silver star Osram Headlight bulbs
Rear wiper delete
Valeo wiper blades
25% tint need two front winds redone.
Polk Audio 12inch Sub with 750 watt amp. Custom into side where CD changer was ( its not finished still need to be smoother and cover its only functional... Your choice if you want it)
The Body is in good condition. No rust it has some dents and ding along each rear quarter panel, and dent in the rocker and normal everyday road chips hear and there.
The car will come with stock 16 inch wheel and Blizzak snow tires
The car KKB's $7,000 I'm asking 7,500
It will need a new crack pipe bc there is a small leak but ive been driving it just fine without having to add large amounts of coolant, but I should have the problem fixed before it is sold.
More pics to come, its to dark now so I should have then up on Wednesdays.
Contact me by PM or at [email protected]
