Results 1 to 16 of 16
    Senior Member Two Rings 215 Motoring's Avatar
    Oct 13 2007
    01 S4 Stg3 Bound, 05 R1
    The 215 & 302
    Angry Urgent: Need A Tech "Philadelphia Area"
    Hello i need someone to come get my car started and running ASAP. I have tools, vag plug Corona's or any beer of your choice. The car is located in Philadelphia, PA please call me for further details at 267-918-7526 ask for Rico. I at least would like the car running by the end of this week.
    Car in question 2001 S4, car is not cranking with key.
    cranks when hard wired from batt to starter wire. Cranks but wont start.
    Thanks for looking guys!!!
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Re: Urgent: Need A Tech
    Letting ppl know the problems or symptoms might help s well as to how big of a job it is.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Apr 05 2007
    It's A Trap!
    Oct 13 2007
    The 215 & 302
    Quote Originally Posted by OldYella View Post
    car is not cranking with key. but cranks when hard wired from batt to starter wire. Cranks but wont start.
    Oct 13 2007
    The 215 & 302
    Quote Originally Posted by exorcet View Post
    It's A Trap!
    No its not a trap
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    did you ground out any wires ? im guessing its the ignition switch take it out n test it wit volt meter
    Oct 13 2007
    The 215 & 302
    Quote Originally Posted by kingofqueenz788 View Post
    will do in the am
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Urgent: Need A Tech "Philadelphia Area"
    shit man... have you looked at the timing belt? Id get a rachet on the crank bolt and run it through to make sure nothing happened there
    - Clint
    Oct 13 2007
    The 215 & 302
    Good Point
    just checked the timing belt and it's fine THANK GOD!!!
    Thanks for the heads up AudiA4 20T
    Dec 09 2007
    01 gti
    boostedville NJ
    manual trans or auto? manual trans possibly the clutch switch?
    VW/Audi
    Oct 13 2007
    The 215 & 302
    Quote Originally Posted by junk t.i. View Post
    Auto/Tip
    Oct 29 2005
    10speed
    San Francisco, CA
    plugs? although they wouldnt just all go bad...
    - Clint
    Oct 13 2007
    The 215 & 302
    well guys just learned that my car is missing the central locking module that is located in the trunk. it sends a signal to the cluster which allows the car to start. i ran a wire (to Ground) from one of the relay's under the driver side dash. Then it cranks with the key!!! anyways ordered the module from A&P AUTO SPECIALTIES, LLC for $80.00 Thanks Chase. dealer wanted $492.87
    now need to figure out y no spark
    Oct 13 2007
    The 215 & 302
    Angry Re: Urgent: Need A Tech "Philadelphia Area"
    today the car CRANK and STARTED!!!
    THE PROBLEM----- a member here was suppose to recode my ECU to a B Box. He F**KED up somehow????
    so Thanks to Marc AKA 10secS4 i got a GIAC B Box from him today and my car Started!!!! After 4 1/2 weeks of touble shooting checking wires and GROUNDS.....
    Now its time to find the "member" that SCAMMED me out of an ECU!!! Not going to mention any names yet. However you know who you are!!!
    To be continued...................
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by 215 Motoring View Post
    was it someone with 2001s4 in their user name?
    Oct 13 2007
    The 215 & 302
    Quote Originally Posted by infinkc View Post
    hmm...
