Well, I was hoping I wouldn't be the only person to reply to my own thread but oh well. We finished the clutch yesterday and so far I have absolutely no complaints. The stock flywheel weighs 24.5lbs and the ECS flywheel weighs 13.5lbs. I wasn't expecting this much difference and was quite nervous at how much the gear box was going to "chatter" and if driveability would diminish. Luckily, the "chatter" is minimal. It only occurs with the AC on, and if the windows are up it cannot be heard. Also the driveabilty is unbelievably good. The clutch feels only slightly more "grabby" than stock but the engagement seems very solid. I've got about 200 miles on the setup so far and have gone to WOT several times, shifting somewhat conservatively. I want to wait about 500 miles or so before I try any type of launch. I'll repost on this thread after I've launched the car.
Also, the engagment is now about 2 inches off the floor!!! It's such a relief (for me) to no longer have a clutch that releases at the very top of its stroke.
One note for anyone who may install this flywheel: There is a shim supplied with the flywheel that has the same bolt pattern as the flywheel. However, there are no instructions telling you to put the shim between the flywheel and crank or flywheel and bolts. We looked up the OEM flywheel in a parts manual and it only shows a shim for automatic transmissions. We thought the shim could be used for spacing between the flywheel and crank for the starter to flywheel relationship but we weren't sure. We finally decided the shim goes between the flywheel and the bolts to protect the surface of the flywheel (even though the flywheel is steel). Anyway, I searched for this info and couldn't find it so hopefully the next person will find this thread.
If you have any questions about the setup or its performance, please ask.
