    Apr 11 2008
    Florida
    Trouble replacing my stock HID bulbs
    I'm able to get the housing out, but once I get to the bulb, I have trouble getting it off the connector. It just won't budge. Is there a certain tool or technique that is needed to use to get these things off?
    2004 A4 Quattro 1.8t - Silver - 6 Speed - Ultra Sport - Stock
    Veteran Member Three Rings KGB's Avatar
    Apr 18 2007
    B9 S5
    Ottawa, ON
    Re: Trouble replacing my stock HID bulbs
    If you are referring to the ignitor, the bulb twists into place so you have to twist the bulb (by the base, don't touch the bulb) to separate it from the ignitor.
    Apr 11 2008
    Florida
    Quote Originally Posted by KGB View Post
    If you are referring to the ignitor, the bulb twists into place so you have to untwist the bulb to separate it from the ignitor.
    Yeah, that's probably what I am talking about. I've tried twisting. I also tried finding this "metal ring" (some one refered me too) to push down, but that hasn't worked either.
    Apr 18 2007
    B9 S5
    Ottawa, ON
    So you've twisted the bulb by the base counterclock-wise and it doesn't budge? Try pushing down on the base as you do it. If all else fails, lube it.
    Apr 11 2008
    Florida
    I'll try lubing. How simimlar are the to taking out the rear tail light bulbs? Those were real easy.
