Results 1 to 16 of 16
    Junior Member One Ring xstiguy19's Avatar
    Apr 05 2007
    VA
    2700-3000rpm issue
    Hey all, I’ve got a question…
    Recently I’ve noticed that between 2700-3000rpm my car runs rough. It’s not like the car is shaking or making any loud noise, it more of a vibration between that rpm range. I thought that the issue would improve when I had the 55k service done, but it didn’t seem to help. Any ideas…
    56k 2004 s4
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    Re: 2700-3000rpm issue
    i feel you.....its were you can feel the torque start to pick up when you step on the gas....
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    One of the motor mounts maybe? have it inspected for broken motor mounts!
    Account Terminated Four Rings
    Apr 16 2007
    New Jersey
    nope, its one of your coil packs pre-failure. and you wont get a check engine light until it fails completely.
    Apr 05 2007
    VA
    Thanks for the help guys.
    Is the coilpack something that would be covered in my CPO warranty from Audi?
    Veteran Member Three Rings colonelburke's Avatar
    Apr 27 2007
    2004 S4 6MT
    South Georgia
    Should be, its covered under my extended.
    Platinum Extended Warranty Mod
    Hoen Xenonmatch Fogs
    Fast Intentions Catback (R,XP)
    Unfortunately sold (traded-in). Dealer is looking to move her for a good price. PM for details and I'll get you in touch.
    Apr 16 2007
    New Jersey
    got mine covered
    Senior Member Two Rings SpfldS4's Avatar
    Mar 04 2004
    2005.5 Audi S4
    Wilbraham, MA
    When did you change your spark plugs? If the answer is no, that's your issue. They are covered at your 55K service. I just changed mine at 32K, had hesitation issues ~3800RPM. When they change the plugs they can look at the coil packs and let you know if that's the issue also.
    2010 Audi S4 S-tronic Prestige Sepang Blue | Sport Diff w/ ADS | GMG Sway Bar Kit | KW H.A.S Coilover | APR Stage 2+ w/ coolant system | 19" OEM RS4 Wheels | RS5 BBK | NAV | Black Nappa | Piano Black Trim | Black Optic | B&O | Advanced Key | 35% Tint | 3M Clear Bra | Audi exclusive
    Apr 05 2007
    VA
    I just changed them at 55k (about 1k ago) and thought that it would improve the problem, but had no luck. I am getting better gas mileage though
    I guess I’ll just take it to the stealership and see what they say. Is this something that I can test with a VAG? It would be nice to be able to tell the guy at Audi that the problem is definitely the coils because my VAG said so.
    Apr 16 2007
    New Jersey
    tell him they are definetly the coils from your knowledge of tuning and maintaining audi's.
    and a VAGcom wont tell you anything until the coil completely fails and you get a flashing check engine light. until then you are left guessing
    Registered Member Two Rings swoyekr.'s Avatar
    Feb 21 2008
    SE PA
    It's covered. I had one fail, replaced, another failed, so I got them to replace all 8
    04 s4 - .Milltek catback SOLD
    Current daily - RSX TYPE S
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    On my first S4 I had one go bad and my dealer got all 8 covered for me as a preventative measure. I am having a little bit of a miss at idle on my current car and suspect that I have one on its way out. Hopefully they will get all 8 covered under warranty on this car as well.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Registered Member One Ring pinacocacola's Avatar
    Apr 25 2010
    Utah
    Quote Originally Posted by 91gl View Post
    Where should I look for coils at? Checker cause its close or online cause they are inexpesive. As well as spark plugs. My B6 has the same problem. under load the engine hesitates, skips, slips, right at 3000 rpm to 3300 rpm.
    Last edited by pinacocacola; 04-25-2010 at 06:32 PM. Reason: forgot to say i have the same problem
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    this sounds similar to my problem.. slight hiccup/flat spot around 2-3k at 1/4 throttle with normal driving.. WOT car is fine. i put in a chevron fuel injector cleaner with techron fuel system cleaner and it was improved while it was still in the tank. next tank it went back to the problem ):
    spark plugs and coil packs were both changed as well as the fuel filter.
    please let me know if you solve this issue..
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Apr 25 2010
    Utah
    I tried new coil packs. The hesitation or sputter I had right at 3000 rpm was caused by a slightly loose spark plug. I drove for 90 minutes yesterday to prove that it had fixed the problem and.. no hesitation. Its simple but check the spark plugs, make sure they are clean and tight.
    All the coil packs tested in at around 380 m ohms
    Sep 16 2008
    Quote Originally Posted by pinacocacola View Post
    i will recheck them.. i also bought some techron fuel system cleaner and some MAF cleaner. hopefully after doing these it will fix the issue.
    PREVIOUS:
