Results 1 to 2 of 2
Thread: Running Rough
    Established Member Two Rings Nick's Avatar
    Nov 30 2005
    95 RX-7, 02 TT, 02 Avant, 00 A4, 00 Golf
    Houston
    Running Rough
    I'm posting this for my brother whom I sold the car to a while back.
    I have a 2000 b5 with a newly installed gt28rs ran great for a few weeks, blew a coil pack. Replaced the faulty one, and it was good to go. The next day it seemed to blow another one, or so i thought. Replaced all of them. Didn't fix the problem. I've replaced both o2 sensors and swapped MAFs and still no progress. I have good compression and good spark in all four. Here is the codes she is throwing.
    Address 01: Engine
    Part No: 4B0 906 018 P
    Component: 1.8L R4/5VT G 0006
    Coding: 07201
    Shop #: WSC 06335
    7 Faults Found:
    16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
    P0140 - 35-10 - - - Intermittent
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-10 - - - Intermittent
    17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
    P1114 - 35-00 - -
    18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
    P1606 - 35-10 - - - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    17524 - Oxygen (Lambda) Sensor Heating; B1 S1: Open Circuit
    P1116 - 35-10 - - - Intermittent
    17513 - Oxygen (Lambda) Sensor Heating; B1 S2; Heating Circuit: Short to Plus
    Any help would be great. I've checked the timing because I thought it might have jumped a tooth, but the timing looks good. The car was running well for several weeks on the GT28.
    What / where is the Lambda sensor? I assumed that was O2 sensors, but new O2's didn't remedy the codes.
    Is the 'charge pressure control' the waste gate controller or the diverter valve?
    Nov 30 2005
    Houston
    FYI, this was due to the dual mass fly wheel seperating.
