Results 1 to 14 of 14
    Active Member Two Rings A4Guy's Avatar
    Sep 07 2007
    Problems with my A4 :(
    Hey Audizine, my A4 hasnt been running well lately. In fact, its stalled 3 times and its automatic transmission! My mods are Apr 91 program, Eurocode Test pipe, and a Forge blow off valve spacer.
    I have noticed it stalls when I am in D and if i hit the brakes the car downshifts from whatever gear it is in and when it reaches 1st gear the rpm drops very low and the engine dies.
    another problem i have noticed is when i am exceeding speeds of 100mph (on the track) there is a huge turbo lag and this is in D only. from gear 4 to 5 its ok then around the top end of 5 car is goin nowhere. gas pedal is floored and the car is not goin anywhere not even goin 6th cuz it wont lol. The only solution i found was to put it in S.
    Nov 12 2007
    Grand Junction, CO
    Re: Problems with my A4 :(
    My advice....Get flashed back to stock, take it to the dealer and tell them that it's not running well...be vague and hopefully they'll figure it out.
    Veteran Member Three Rings A4addict's Avatar
    Jan 23 2008
    '08 Audi S-line 2.0T A4
    San Diego, CA
    I'm not sure about these FSI engines, but there has to be something that controls your idle speed, like on older cars, they're called "idle speed control." It's a valve that controls your air intake for your idle speed. I'm not entirely sure about our engine, but if this valve is the problem then it's an easy fix.
    x2, get reflashed back to stock and be very absolutely vague at the dealer.
    APR 91/93/100, Forge DV, Debadged, PIAA, Blacked out filler/grille/reflectors/fog covers,
    2.5" custom catback, Remus axleback exhaust, H&R Coilovers, Vredestein Ultrac Sessanta 235/35/19 tires, 19/8.5" BBS LM reps, RS4 centercaps, EVOM intake, 35/5% tint, Lamin-X
    | Caution: Asian driver |
    Sep 07 2007
    thx for the advice guys. im gonna avoid the dealer atm because i have a testpipe and if they c that then the warranty is done lol. imma take it to a shop i know and get a checkup most likely its gonna be the ripped dv and it is an easy fix. i was just worried that it mite be a bigger problem but i hope it isnt.
    Jan 01 2008
    Long Island NY
    Good Luck, like everyone else said flash it to stock and go to the dealer, when your under warranty no need to worry:)
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Take your BOV off
    -Kris
    Jan 23 2008
    San Diego, CA
    Oh yeah, that too. Take that spacer off, even before you go to the dealer.
    Nov 12 2007
    Grand Junction, CO
    The tp will not void the warranty. The BOV and chip though, could be a problem.
    Established Member Two Rings RisR32's Avatar
    Jan 15 2008
    Philadelphia
    I don't know if this will help you but.. I had a manual vw that was chipped and had other things done to it, it started stalling on me while I was driving.. Like on a highway and such or crusing down a hill. It would just stall... If thats the case I would say its the chip. I got another company to re-flash my car and everything ran perfect from then on...
    04' DBP R32 SOLD, 06' A-4 2.0t SOLD, 10' GTI SOLD, 11' A-4 2.0t Titanium Avant SOLD, 2012 TTRS SOLD, 17' S3 SOLD, 18' RS3, 19' Q8, 2021 RS6 Avant
    Registered Member Two Rings
    Apr 03 2008
    MD/NC
    I had the problem with my 01 a4 when I was still under warranty and stock....it would randomly stall every 15minutes...it was a bad ecu (the dealer said), they fixed it and it never happened again...also im no mechanic but maybe the tp is making the car run rich
    Active Member Two Rings JCleary's Avatar
    Feb 26 2007
    '07 A4 Avant
    Menlo Park, CA
    I had a similar problem with my bone-stock B7...
    Turned out to be a faulty fuel pressure sensor. No biggie, fixed under warranty and it runs ok now. The problem now is that the PCV valve is shot. The dealer's solution was to replace the oil cap. Yeah, that sure worked. Now oil is puking out of the valve cover bolt holes.
    Have the dealer check it out. They shoud be able to fix it no problem.
    Registered Member Two Rings coryliv's Avatar
    Feb 09 2006
    VA
    I agree to get rid of the BOV spacer. I assume this allows your setup to release pressure? Our cars are meant to recirculate it back into the system. You should also look to have it flashed back to stock to see if it will fix any of your issues. I know there is that CH recall right now which would require the dealer to overwrite your ECU. Either schedule service or have it done during your next oil change.
    ________________________
    2006 A4 2.0T Quattro
    Moro blue, grey leather, 6 spd, sports suspension, GIAC, RS4 rear sway
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    are you just using the forge spacer? or is it a forge DV with a spacer? cause if your just using the spacer, there is your issue
    Active Member Two Rings Tunerstop's Avatar
    Jan 22 2008
    Socal, CA
    this might be a software issue..take it back to whereyou got your apr, and see if they can reflash the car with apr.
    08 A4 S-Line 2.0T - TSP BOV, H&R Springs, 20% Tint, 6000k HIDS, 3000k Fogs, 19" BBS LM's
