i have 98 B5 giac chipped. I usually get around 15psi & everything was fine Friday but when i went to drive Saturday, that was it. I was working on my heat shield friday and was moving the air box around etc. but i checked everything all the tubes and hoses that are attached to the lid of the airbox.
Now i boost to almost 10psi. and its weird when i am in any gear and let off the throttle, the boost reads -25psi. It idles fine at around -19 in the hose pressure. Even when im driven, the gauge reads 0 or below. i have to almost floor it to get it over the 0 degree mark. I used to be able to floor it and hit 15psi no problem.
. I still boost at like 10psi or so I can hear the turbo, it sounds different. I think bc of the possible leak. It sounds like the turbo spinning up ut i think i hear the leak. My pick up is no where close to what it was but i still feel it pull some. So i dont think its the turbo.
Im going to check the DV with my stock one. When i was fooling around with the airbox, i was moving the top of it around and the only thing i unplugged was that wire that goes across the top if the airbox to the N75. I checked the connection and its in.
I might have leak and im going to make that little tool that people talk about on here to test my pressure out. Can turbos run in reverse? It just seems weird that it drops that much when im off the throttle and i cant boost like i used to!! any advice??? thanks in advance
