Results 1 to 25 of 25
    Senior Member Three Rings eurotecknik's Avatar
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Cylinder Compression Test?
    Hey guys, how do you get a compression test done? Did you give it to a mechanic to do it? I called a local tuner and they said they can do it. It would take an hour of labor x $109/hour. So I am looking at $109 to get this test done.
    What do you think? Particularly people who have done this.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Cylinder Compression Test?
    Just go buy a compression test gauge from your local auto parts store or sears, they cost around $25. Doing the test is very easy, you just pull all 4 spark plugs out and test 1 cylinder at a time by cranking the motor till the gauge stops moving.
    You can hang the gauge from the latch on the hood using a bungee cord so you can see it from the driver seat.
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Thanks Mike, I will see what I can do
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    It's worth the time and effort to do it yourself. Unless for whatever reason you're not comfortable doing this test on your vehicle. If so I'd say find a local automotive training facillity and have them do it. Labor is "free" there.
    I bought mine for $25 and it came with instructions. Just make sure while you're cranking to disable the ignition and the fuel injectors. Pull the primary side of the coil harness to disable the coils. In a COP setup just unplug them.
    Jul 07 2004
    socal
    Quote Originally Posted by djwimbo View Post
    Correct, you can also just unplug the cam sensor harness or just unplug all 4 injectors so that there is no fuel being sprayed into the cylinders while cranking the engine.
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    So, what specification range per cylinder should I be looking at? What is considered good or bad?
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Quote Originally Posted by eurotecknik View Post
    As long as they are within 10% of each other, you are fine... And the Bentley states to unplug the cam position sensor, this disable the coils AND the injectors. Also, when cranking, it is best to go WOT...
    ΜΟΛΩΝ ΛΑΒΕ
    Jan 21 2005
    sf bay area
    where is the CPS? and why would you go WOT?
    Quote Originally Posted by Ewok_Fetus View Post
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    So you can compress as much air as possible.
    Jan 21 2005
    sf bay area
    duh.. because engines do not work on fuel alone. =)
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by ILoveT View Post
    Kinda, It's more to the effect of maintaining the same amount of air supply to each cylinder as you move from #1 to #4. If you do the test with 1 & 2 w/ the throttle plate closed and 3 & 4 @ WOT, the readings will be different.
    Do all 4 under the same conditions. If you have a battery charger available, hook it up as well. This is to try and maintain battery voltage so the cranking speed will not slow down as you progress.
    97 A4 2.0TQM
    Rochester, NY
    and try not to crank the engine for more than 5 seconds at a time or you could damage the starter
    Jul 07 2004
    socal
    You don't need to press the throttle(does nothing on the DBW anyway), if you take all 4 spark plugs out while doing the test the amount of air being supplied to all 4 cylinders will be equal.
    Mar 04 2007
    nothing
    nowhere
    Quote Originally Posted by pac1085 View Post
    I swore it was 10 seconds. And you must wait 30 seconds between cranks... At least that is what my owners manual is saying...
    Mike, have you looked at the throttle body while doing a compression test on a DBW? It does open and stays open while cranking...
    ΜΟΛΩΝ ΛΑΒΕ
    97 A4 2.0TQM
    Rochester, NY
    Well, it's something like that. Either way, don't crank it over for like 30 seconds.. lol
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    By the book it's 15 seconds, but it also calls for 5 compression cycles. Which is less than 3 sec anyways.
    After 10 Sec the windings in the starter get too hot and you can damage the armature and such.
    Jul 07 2004
    socal
    The ecu controls the dbw throttle body during cranking so it isn't like your food on the pedal is doing anything at that point.
    BTW yes I did CR's all the time back when I was dbw.
    Dec 05 2007
    Bump: I am a noob and am about to attempt this properly. I looked in the Bently manual and it said that the cam sensor is located behind the top of timing belt cover. I looked and is that the sensor that is on the top right area which is sticking out from behind the cover? If you need pics, just request. Thanks!
    *I bumped this thread because it says I need to remove cam position sensor and am requesting if it is correct plug
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    Yes thats the one, pull that, or pull the ICM plugs just need to stop it starting up or anything
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Jul 07 2004
    socal
    Yes that would be it. You can pull that, or unplug the injectors or even just pull the fuel pump fuse. You just want to make sure the injectors are not spraying while cranking the car.
    Dec 05 2007
    Just did it. And I am amazed a shop would charge $110 for a simple job like that. Autozone even let me rent thier compression tester for free (well, $35 deposit. going to go and get money back now)
    Cylinder 1-165
    Cylinder 2-165
    Cylinder 3-170
    Cylinder 4-165/170
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Do you have to pull the cam position sensor? Coils will be disconnected anyways so I'd just pull the injector connectors.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Dec 05 2007
    I just did the easiest route and took Mike's suggestion to pull the fuel pump fuse. If I did not go that route, I would have just unplugged the cam position sensor and did it.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Quote Originally Posted by nebone22 View Post
    word, thats the way i did it...
    and for the record, throttle open vs shut is the same even on DBC, i tested it both ways... and the proper way to do a comp test is to crank it until it stabilizes, which is usually 4-5 cranks for me... the 1st puff is also key, but youll need someone else to record it, they should all be within 15% on the 1st puff
    Dec 03 2005
    2 pedals 1FG
    connecticut
    -Doug
