Results 1 to 22 of 22
    Senior Member Three Rings GyzmoS4's Avatar
    Feb 07 2006
    Bronx, NY
    Why is my oil temp going so high?
    I changed my oil a little over a month ago. I used shell full synthetic (5w-30). Noticed my oil temp would get to almost 250 after a few short pulls. So i changed to royal purple 15w-40 last week. But i'm still having the same issue. And this happens even on cool nights when it's not even above 65 degrees. Is something wrong? TIA.
    J-Fonz tuned Stg 2+
    "Two wrongs don't make a right, but it makes us even."
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    Re: Why is my oil temp going so high?
    i had similar issue, my would fluctuate up and down all the time and even go to the max temp. I replaced my Oil Temperature Sensor on the bottom of the Oil Pan and that took care of the problem
    Feb 07 2006
    Bronx, NY
    O ok. But mine doesn't fluctuate, it just keeps going higher until i slow down for a bit. It gets to 225 so easily now. Haven't seen temps this high since last summer. Do you think my temp sensor needs to b replaced?
    J-Fonz tuned Stg 2+
    Dec 06 2007
    Calgary, AB, Canada
    Replace it and see. It's a cheap possible solution.
    Veteran Member Four Rings KompMan420's Avatar
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Are all of your fans working properly? Outer and inner electric ones...
    SOLD - 2001.5 Audi S4 Twin Turbo ~ 450hp
    Mods - AWE/GIAC Stage 3 | AWE Intercoolers | STaSIS Coilovers | RS4 Clutch | 3" Borla Cat-Back | ASP DTS | JHM Solid Axles | "Piggie" downpipes | Neuspeed SS | AWE Pedals | IceLink for iPod | 710n DVs | M3 Spoiler | LM Reps 18x8.5 Satin Black w/red Time Attack
    www.NJSRealty.com
    Feb 07 2006
    Bronx, NY
    Ok, guess i'll try replacing it then.
    I haven't checked the fans, but i assumed that the engine temp would go up also if the fans weren't working. But i will check those also. Thanks guys, i'll let you know the turnout.
    J-Fonz tuned Stg 2+
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    I had my inner fan go out and saw higher than normal oil temps, but yes the coolant temps rose too. Try the sensor. Also, have you scanned for any possible codes?
    www.NJSRealty.com
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    Could it be from the weight of the oil?
    He is using 15w40 I thought the car required 0w40
    Just a thought
    Marty
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Quote Originally Posted by dak360rt View Post
    Just a thought
    Marty
    That heavy weight would make it harder to reach those temp as quick
    2010 Brilliant Black/Magma Red S4
    Apr 17 2008
    Sacramento, Ca
    Good knowledge
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Yea, I'm thinking of switching up to a 15w-50 for the summer cause it's so freakin hot in FL
    www.NJSRealty.com
    Jun 14 2007
    2000 S4
    Connecticut
    yeah i bet your heatsoak is awesome there on stock IC's!
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Neh, I've got AWE's in there now. ;)
    www.NJSRealty.com
    Jun 14 2007
    2000 S4
    Connecticut
    oh really. bastard.. how do you like them. my new plan is rocking my FMIC setup until waterfest, then buying them when they are discounted for the show. i just wanted an upgraded intercooler since i ll be doing the fueling real soon ya know. lmk... and the new ones you got ?
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    They are pretty freakin' sweet man! It's still too hot to really get a feel for the extra power. In FL, it can go from a chilly 55-60 degrees to a blazing 80-85 from one day to the next. It really seemed like the day before I got them installed it was nice and chilly and the day after and every day since it's been hot. I will say this though, the damn thing just keeps pulling and pulling all the way to redline. On the stockers, there was a definite wall and drop off. I HIGHLY recommend them!!!
    No, I think I got the last set of the old style from Matrix. Apparently I wasn't good enough to get the new style...
    www.NJSRealty.com
    Dec 17 2007
    MI
    Where is the temp sensor on the oil pan? This will be great info!!!!!
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    my oil is getting very hot too.. just normal driving with boosting up to 10lbs i will see 225 in half hour after it is warmed up. my initial thought was because i never upgraded my oil lines when i went stage 3 (dumb idea) and because i have an fmic w/ removed fan. however, i am running 0w40 oil, so this summer i will be getting something a little thicker and maybe that will help? i will let you know how it goes.
    ThorTechnik.com
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Quote Originally Posted by timjadams View Post
    Jack up the car, remove the plastic belly pan, look at the oil pan and you can't miss it.
    www.NJSRealty.com
    Dec 06 2007
    Calgary, AB, Canada
    ^^yup, right on the bottom of the oil pan.
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    So I wonder, at what level do oil temperatures really become a concern?
    As it's heating up here i'll see my S4 (stock) running normally between 90-105C (195-220F) when fully warmed up, even pushing it some. I get the impression these levels are not a problem at all. Never seen it get to 120C (250F) but i'm sure with some pushing it could get there.
    As far as the owner's manual is concerned, if temps go into the "higher ranges" let it cool down/take it easy until they ease back into the lower range. If they don't, service time.
    Brilliant Black 2001 S4 - 6MT <3
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    id do what greg said (2001s4Ny) and change that sensor..
    Feb 07 2006
    Bronx, NY
    Are any of these what i'm looking for?
    http://www.ecstuning.com/stage/edpd/...l=&engine=2.7T
    They say oil temp sender. Same thing?
    J-Fonz tuned Stg 2+
