Results 1 to 13 of 13
    Apr 08 2008
    03 Avant 3.0L Quattro (6speed)
    Philadelphia
    235 or 245/35/19?
    That is the question. I will be picking up a new round of rubber shortly. I am torn between sizes. Any insight, comments or suggestions would greatly be apprciated. I have an A4 B6 Avant Quattro.
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    Re: 235 or 245/35/19?
    245/35/19
    Senior Member Two Rings has6's Avatar
    Aug 06 2007
    '21 SQ5 | '20 XC40
    Brooklyn, NY
    What is the offset on the wheels? You may have some rubbing issues with the 245 depending on the width of your wheels. There's nothing wrong with the slight stretch of a 235 tire, compared to a 245.
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    and yes depending on the offset.
    Apr 08 2008
    Philadelphia
    35mm offset. The car will be lowered shortly as long as the StaSiS Group buy happens.
    Senior Member Three Rings onept8tee's Avatar
    Apr 18 2004
    Westminster, CA
    do a 235 with a 35mm offset
    Veteran Member Four Rings 02silverb6's Avatar
    Nov 20 2006
    ATL, GA
    I run 235/35/19 all around. 19x8.5
    PM me if you need RNS-E installed in Atlanta area
    R.I.P 2002 Audi A4 3.0
    Active Member Two Rings RyMo's Avatar
    Sep 17 2007
    Beaverton, OR
    I'm running 245/35/19 with +35 offset on mine at stock (non sport) suspension. I "do" rub in reverse with the wheel cranked, but nothing terrible.
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    im going to do 235s next, im on 19" RS4 reps
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Quote Originally Posted by 02silverb6 View Post
    x2 and this is the most common set up.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Veteran Member Three Rings PRVWing's Avatar
    Jan 18 2005
    Puerto Rico
    i run 235/35/19 on 19x8.5's with 35mm offset with no rubbing on sport suspension. was thinking of going 245 but i really dont want rubbing issues...
    FlexTuning
    White USP A4 1.8TQ6MT
    K04, 380cc injectors, GIAC Reflash, HKS BOV, PSi TP, Milltek exhaust (with Magnaflow mufflers), AWE FMIC, Samco TIP, Neuspeed snub-mount, Neuspeed Power Pulley, Stratmosphere short shifter, Stratmosphere clutch, B6 S4 front and rear brakes, stainless steel brake lines, RS4 19'' reps, RS4 rear sway-bar. NEW Bilstein Sport Shocks, and H&R Sport springs!
    Veteran Member Three Rings Carbon's Avatar
    May 24 2005
    2004 E46 M3
    San Diego, CA
    Quote Originally Posted by Siggiepop View Post
    245/35/19
    x3, i'm running the same setup
    03 A4 - Sold
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    I run 245/35 with et34. I shaved off the little tab at top center of front well, and about 2" of carpet around the rears. No rubbing, lowered to about 25.5 all four corners.
    Before that I only rubbed the carpet... as porno as that sounds, lol.
    My 2004.5 APR Stage 3+ is SOLD
