Results 1 to 18 of 18
    Oct 29 2005
    10speed
    San Francisco, CA
    Best thing ever?
    - Clint
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: Best thing ever?
    I dont get it. explain
    Dec 06 2007
    wow iss a Lug bolt! WOOOOOW!
    -Kirk
    BetaAlphaTau Member #58
    Sep 24 2007
    Woodbridge, Ontario
    Oh I see. That is pretty cool. Is it reliable?
    Veteran Member Four Rings HeHateMe's Avatar
    Apr 05 2005
    lost wages, nv
    they are bolts that allow different sized wheels to fit onto our bolt pattern. Read the ad.
    <old school>
    --giacfxk03-siemensinjectors-milltekexhaust-ofestage4clutch-eibachprokit-stratmosphereshortshift--
    abracadabra homes http://www.audizine.com/gallery/data...une_06_142.jpg
    Active Member Four Rings
    Dec 11 2006
    Boston
    I saw those the other day. I can finally buy a 5x114.3 wheel and have them fit my 5x112!
    Stage 3+ RS6's
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    These have been around for a while. Just make sure the bore on the 114.3 wheel is large enough to allow the bolt to shift.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Seen 'em. Better hope the offset of the wheel is exactly what you want.
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    i would hope that you got the right Hub Centric rings other wise that could spell disaster. Its one thing to shift the bolt pattern but another to not have the hub centered in the rim it would be a bumpy ride.
    I vote no, and recommend quality adapters or wheels made to fit our cars, there are enough out there that we don't have to start using wheels off evos, eclipses, Chrysler's, mazdas, etc...
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    says tuv approved...
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    how durable are those cones?? they arent going to bend or dent from going over bumps?? make sure to torque them down good!!!
    Feb 17 2005
    Sarasota, FL
    I have a few friends that use these with odd wheels not meant for 5x112, they seem to work perfectly!
    Established Member Two Rings shedpress's Avatar
    Feb 02 2008
    03 A4 Avant 3.0 6MT Quattro
    Christiansburg, VA
    I'd think as long as you use the correct torque settings that it wouldn't be an issue.
    :: brian@shedpress ::
    SHEDPRESSdotCOM
    Veteran Member Three Rings Ultra B6's Avatar
    Sep 05 2007
    New Jersey
    i dunno for some reason i feel that this would shift if you hit something hard or at highway speeds..
    -James-
    04 Dolphin A4 USP CLUB MEMBER #84 3.0 QUATTRO TIP
    MODS:
    Pics:http://s231.photobucket.com/albums/ee167/ultrab6/
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Quote Originally Posted by Ultra B6 View Post
    im sure the've addressed this problem in the r&d but idk...i'm still leery
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    These have been around for years. They're TUV approved and OZ used to ship their wheels from the factory with these to save on the manufacturing costs of making wheels in several lug patterns.
    -Darrick
    Apr 04 2007
    PHX, AZ
    How much are a Set of Audi Lugs?
    Paul Cordero
    [email protected]
    Sep 20 2006
    Baltimore
    These are actually a variation on 2-piece lug bolts which are considered safer than the traditional lug bolts.
