Results 1 to 20 of 20
Thread: Tire Shine?
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Tire Shine?
    Whats the best and longest lasting tire shine? I tried so many i dont know anymore. Thanks.
    Registered Member Three Rings oneseba's Avatar
    Jan 22 2008
    Re: Tire Shine?
    Zaino Z-16 and 1Z Vinyl/Rubber care, both give low shine finish and seals/protects them too.
    Established Member Two Rings 2K1Ultrasport's Avatar
    Mar 17 2006
    2001 Audi A4 Sport
    New York
    Re: Tire Shine?
    i've had pretty good results with the optimum tire gel from DD.
    goes on easy and doesnt spray off while driving.
    2001 Audi A4
    Sport Package
    Veteran Member Four Rings aaron1085's Avatar
    Jul 12 2007
    2007 2.0T A4
    NH
    Re: Tire Shine?
    these products available at autozone? i need some better tire shine. NOT impressed with Meguiars spray on shine
    Jan 22 2008
    Re: Tire Shine?
    Phil at DD (sponsor of this forum), good price and quick turnaround (delivery).
    Mar 17 2006
    2001 Audi A4 Sport
    New York
    Re: Tire Shine?
    what he said.
    Phil (detailersdomain) usually gets your order out same day.
    i'm only one state over so i usually get it on my doorstep the next day.
    if you absolutely must get it from a regular store, i used to have decent results with meguiars tire shine gel (purple gel in a clear squeeze bottle, apply with sponge) but i always had problems of spray off if i started driving before it was completely bone dry.
    there were also rumors that they changed the formula and it now browns tires or something.
    you can also try visiting some detailing places in your area to see if they retail any higher end stuff.
    but overall DD FTW
    2001 Audi A4
    Sport Package
    Veteran Member Three Rings Alan's Avatar
    Jan 22 2007
    1998 2.8QM 1988 Corvette
    Pittsburgh, PA
    Re: Tire Shine?
    I use Wet Look tire Dressing from detailking and it works amazing, and is very affordable.
    Jan 22 2008
    Re: Tire Shine?
    Quote Originally Posted by 2K1Ultrasport View Post
    Even the spray one does, I stopped using it rightaway.
    May 31 2007
    Montreal
    Re: Tire Shine?
    Is optimum better than VRT?
    VRT is great cause it doesn't splash, but last maybe 3-4 days.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Tire Shine?
    I just tried a new gel from black magic, got it at autozone. It looks good going on 5 days now even driving by a cement plant.. Damn dust. I did let it dry dry for a few hours before driving, no sling.
    Aug 04 2007
    US
    Re: Tire Shine?
    This:
    http://www.blackmagicshine.com/produ...m-tire-wet-gel
    Got it at Autozone and it works great!
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Tire Shine?
    ^^ that's the stuff..
    Mar 17 2006
    2001 Audi A4 Sport
    New York
    Re: Tire Shine?
    i've never used the vrt so can't compare.
    i know a lot of people love the vrt.
    the only thing you should be careful of with the store bought stuff is the browning issue.
    there's a certain chemical that causes the browning, can't remember the chemical off the top of my head.
    "Other Degradants
    Petrochemicals and silicone oils can remove the protective waxes and increase the rate of degradation. Common automotive "protectants" and "tire dressings" are typically devoid of UV stabilizers of any type and contain petrochemicals and/or silicone oils which dissolve away the protective waxes and can actually aggress the sidewall. In the event of warranty sidewall failure, one of the first things tire manufacturers look for is evidence of the use of these types of products. When found, this is often cause for not warranting the sidewall failure."
    so yeh, make sure whatever you use doesn't have any of those in the ingredient listing.
    2001 Audi A4
    Sport Package
    Dec 19 2007
    York, PA
    Re: Tire Shine?
    i personally like eagle 1's product...easily available...and works great.
    Dec 19 2007
    York, PA
    Jul 12 2007
    2007 2.0T A4
    NH
    Re: Tire Shine?
    thanks guys!
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 24 2004
    Re: Tire Shine?
    use an apc (all purpose cleaner) to clean up the tires and u will not get browning from any tire dressing that's the key, clean the tires and then dress it.
    I like both Optimum and Adam's.
    Use a foam applicator apply more for gloss or switch the the dry side of the foam applicator to matte it down for a flat finish.
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    Re: Tire Shine?
    no touch seriously wet, comes in an aerosol can, spray it on and let it dry for about 20-30 min. and your set.
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Re: Tire Shine?
    Quote Originally Posted by n7plus1 View Post
    The Tire Shine Gel works even better than the spray, the downside is you MUST use a foa applicatir, the plus side is most bottles come with them. You don't have to wait for it to dry, doesn't sling onto your wheels and if you accidentally spary it on your wheels it come right off. It gives a great wet look that I used to get from Black Magic which is also really good, but I got tired of making sure it was dry before I drove.
    Senior Member Two Rings dannyvox's Avatar
    Mar 25 2008
    new york
    Re: Tire Shine?
    usually use black magic or Armor All
    usually prefer the ones in the can easy coating and lasts
