Results 1 to 3 of 3
    Veteran Member Three Rings ChumbaWumba's Avatar
    Jun 06 2007
    noob question please help
    if a wheel has the same offset as factory...does that necessarily mean it will clear factory brakes???
    TIA
    -jeffrey
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: noob question please help
    The thickness and shape of the spokes can play into the ET needed to fit the car, so its not a guarantee if the ET is the same. It would be worth a test fit if possible !
    Jun 14 2005
    Anaheim, CA
    Nope. Spoke design and barrel design come into play. If ET is the same, that means it just sits on the same position on the hub as your stock wheels, but spoke and barrel clearance could be different.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
