definitely try tightening all your screws. If that doesn't help, take the headlight out, and check if the Auto-leveling motor's ball joint popped out of its place. It's not very probable that that's the case, but you never know.
It's located on the side of the headlight, behind the long beam reflector. Take the metal clip off, that holds the black plastic onto the headlight, than take the black cover/plastic off. That'll expose the motor. If the motor's ball joint isn't attached to the white clip, it'll make the projector and long beam assembly free to move inside the headlight, thus shake and bounce every time you hit a bump.
If you need a picture of it just let me know.
