Results 1 to 13 of 13
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    Boxster Calipers
    I have done a lot of searching and actually answered some of my questions but I still have a few more. I can get a set of boxster calipers for free, since I was going to get the a8 kit it will hardly cost anymore for me to run these calipers. I have seen pictures and read that they will fit behind stock 16" 10 spoke sport wheels but I'm assuming this is with a small spacer. Does anyone know what size spacer is needed? What is the best solution for brake lines since I read that the stock lines won't work.
    The calipers are from a 2003 boxster, I'm assuming the calipers from this year will fit the carriers from PureMs? If anyone has pictures of them behind stock 16" rims please post them up.
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Feb 15 2007
    marimont
    Re: Boxster Calipers
    PureMs sells the mounting brackets for 175 and the lines for 89. Not sure on the spacers. I would just do 10mm ones. Which should give you more then enough room behind the wheel and not too much poke.
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    what?! how're you gettin em for free??!
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Jun 05 2007
    Portland, ME
    I'm special and know people at an Audi shop :)
    2008 R32
    2015 S4
    Senior Member Two Rings slayerrule's Avatar
    Nov 02 2006
    50 trimming
    sloatsburg, new york
    make sure you are getting non s boxster calipers
    Jun 05 2007
    Portland, ME
    Quote Originally Posted by slayerrule View Post
    Thanks, I know not to get the S calipers.
    2008 R32
    2015 S4
    Registered Member Two Rings SilverB5A4's Avatar
    Jan 19 2007
    RIP '01 A4 1.8TQM, 96 VR6 GTI
    GA
    3mm minimum, i had 5 mm spacers on mine when i ran the stock wheels.
    GIAC chip - Koni coilovers - Purems Boxster calipers and A8 rotors - CPP Adjustable Front and Rear upper control arms - H sport sways - B7 S4 BBS CH 18" - 2.8 transmission
    981CGTS, Cayenne Turbo, '22 A4 Allroad
    Chicago 'burbs
    Quote Originally Posted by jm121189 View Post
    Old picture when trying to determing spacer size. ECS has 2, 3, 4 & 5 mm spacers 5mm are the easiest to get ( H&R ). I would choose the 4 (ECS Tuning part) or 5 mm ( H&R even Tire Rack carries this) spacer.
    2014 A4Q Red w/ black optic black interior
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    A8 behind 16" Swings.
    A8 Boxster behind 16" Swings, small spacer.
    Jim
    I Do Werk.
    Senior Member Three Rings sbghms's Avatar
    Jan 02 2008
    2001 Audi A4 1.8TQSM
    WA
    haha the first pic reminded me of those auto zone rimes that use a metal plate thing to cover up the crappy steel wheel behind it.
    Quote Originally Posted by onemoremile View Post
    Mar 09 2004
    nw michigan.
    They do look better behind prettier wheels.
    Jim
    I Do Werk.
    Jun 05 2007
    Portland, ME
    Thanks for the pics and info on spacers, hopefully I can have them on in a week or two.
    2008 R32
    2015 S4
    Jun 05 2007
    Portland, ME
    Here are some pictures of the calipers just for fun. The pads in the pictures are getting replaced.
    2008 R32
    2015 S4
