Results 1 to 15 of 15
    Senior Member Three Rings oakenfolde's Avatar
    Jul 24 2007
    Las Vegas
    help me out here please, do i need new wheel bolts
    my wheels are aftermarket, +38et and i bought 10mm spacers for the rear.
    Do i need new lugs in the rear? and i dont know what style the bolts are either, so i dont know which to buy.
    should i just call the place i ordered them from?
    2005 turbo Acura Rsx-s
    2007 Ibis White A4 Quattro S-line
    2009 Tahoe Z71
    2013 A5 S-line
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Re: help me out here please, do i need new wheel bolts
    Yes you'll need new bolts. Simply add 10mm length to your existing ones.
    Jan 06 2008
    Dacia Sandero
    Arizona
    most aftermarket wheels require conical bolts as well.(oem are flat) keep that in mind.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by 4RingRook. View Post
    OEM is ball.
    At least thats what they were on my S.
    My Champions also take ball seated.
    So it all depends.
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    OEM Is Ball
    28mm is OEM Bolt size so get some 38mm, and contact that place you got the wheels from and see what they can tell you!
    Veteran Member Four Rings LAS's Avatar
    Feb 12 2004
    HI.
    didn't we go through this already...
    Jul 24 2007
    Las Vegas
    ill just take one bolt off and see what style it is and measure it.
    2009 Tahoe Z71
    2013 A5 S-line
    Veteran Member Three Rings felondnb's Avatar
    Jan 12 2008
    London, UK
    any more info on this?
    and also - what about using the OEM locking wheel nuts? can i run 4x 33mm (for 5mm spacers) and 1x OEM locking nut on each wheel?
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    Feb 12 2004
    HI.
    Quote Originally Posted by felondnb View Post
    it 'may' catch but you'll be short on thread if you use the oem locks. at least a recommended(Tirerack) minimum of 7.5 turns should be followed. i'd just get the correct size locking lug bolts.
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    If you want wheel locks but you are running spacers, get an external lock.
    One of the places you can buy them at, is FogCity. Here is their thread: http://forums.vwvortex.com/zerothread?id=3418453
    Here they are on my old wheels. Sorry they're a little dirty
    Ignorance is bliss.
    Veteran Member Four Rings aaron1085's Avatar
    Jul 12 2007
    2007 2.0T A4
    NH
    which i just learned the other day at Town Fair Tire...
    but with alittle fancy talking, i got some free ones.. (i bought wheels somewhere else and had them put the wheels on)
    Jan 24 2007
    Wisconsin
    Our oem bolts are ball seat lug bolts.
    Aftermarket oem wheels (like BBS) use ball seat lug bolts.
    99% of other aftermarket wheels (replicas, Rial, IForged, OZ, etc) use conical seat lug bolts.
    I've never seen a german automobile that required a flat seated lug bolt.
    OP needs extended, conical seat lug bolts. 14x1.5x38mm to be exact.
    oem bolts are 14x1.5x28mm, and he wants to use 10mm spacers. You can buy H&R 14x1.5x40mm (2mm longer won't matter) for $2.95/bolt HERE for example. Almost any vendor can sell you the lug bolts you need though.
    Ignorance is bliss.
    Jan 12 2008
    London, UK
    Quote Originally Posted by LAS View Post
    hmm... spoke to a wheel specialist & they said 4 turns is safe?! doesn't sound it to me, so i'll have to get some longer ones i think.
    Jun 14 2005
    Anaheim, CA
    That doesn't sound right... At least 6-8 full turns is safe. Then drive for 50 miles and re-torque again.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Jan 12 2008
    London, UK
    Quote Originally Posted by VMRWheels View Post
    -Charles@VMRWheels
    cheers, i'm gonna get some longer bolts to make sure, though 5mm is prob only about 2 threads worth, right??
