Results 1 to 25 of 25
    Dec 01 2007
    Markham, Ontario
    Rubbin issue - what's ur fix ?
    I got a set of tein SS coils and ABT SP1 19x8.5
    the car is definitely slightly rubbin over small bumps, for the front, I took out the screws and folded the tabs (rubbin gone)
    but for the back, it's definitely rubbin on the carpet, there is mention that i should shave the carpet a bit.. does anyone have pics of shaved carpet or more detail steps ?
    thx !!!
    2015 BMW M3 Alpine White
    2013 Phantom Black RS5
    2012 Audi TTRS Black / Black - Sold
    Plus One
    Gabriel
    3255 Highway 7 East Unit 159
    Markham Ontario
    Cellular sales / repairs / unlocking / flashing - PM if you need help with anything
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: Rubbin issue - what's ur fix ?
    Just keep rubbing on the fender liner in the rear, it will wear away and you'll be fine in a couple days/weeks depending on how much it rubs. You can also adjust the camber in as well.
    -Darrick
    Senior Member Three Rings dope a4's Avatar
    Apr 06 2008
    08 a4
    VA
    i did negative camber in the back and raised the car up a little cuz i didnt want to rub at all
    Nov 14 2006
    Gig Harbor, WA
    Puss.
    -Darrick
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Can we see what your drop looks like? Whats the offset on those rims?
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Dec 01 2007
    Markham, Ontario
    rub it till it's gone ?
    i read some post to trim 1/4 inch or something but i can't seem to find where to trim
    Plus One
    Gabriel
    Markham Ontario
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    some of you have the most rediculous answers to peoples questions.....i dont know how to solve ur rubbin issue but reading these threads are getting funny
    --roll your fenders
    --raise the car
    --get a less wide rim
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    You guys have carpet in the back?! Mine are just plain plastic...
    I want my wheels to be carpet munchers when I lower my car
    Ignorance is bliss.
    Veteran Member Three Rings A4addict's Avatar
    Jan 23 2008
    '08 Audi S-line 2.0T A4
    San Diego, CA
    Plastic?
    APR 91/93/100, Forge DV, Debadged, PIAA, Blacked out filler/grille/reflectors/fog covers,
    2.5" custom catback, Remus axleback exhaust, H&R Coilovers, Vredestein Ultrac Sessanta 235/35/19 tires, 19/8.5" BBS LM reps, RS4 centercaps, EVOM intake, 35/5% tint, Lamin-X
    | Caution: Asian driver |
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    Oh yea, my car doesn't rub cause I have negative camber in the back. And the front I have done the same as you.
    The camber isn't terribly crazy but it is noticeable. The bottom of my wheel is flush with the fender while the top is tucked in. I will probably have to switch the tires from side to side to get the full life out of them.
    Active Member Four Rings
    Nov 19 2006
    Ibis 07 A4 S-Line
    San Fernando Valley, CA
    My fronts are cambered like a beeyotch (can't really tell from this pic)
    So I'm also kind of interested in how to get rid of the rear rubbing so I can come down another 1/2"
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Raise the rear of your car back up a little. You might notice an increase in handling performance when you do that also!
    2006 Audi A4 2.0T Quattro 6MT S-line
    Nov 19 2006
    Ibis 07 A4 S-Line
    No.
    AWD_4TW
    ^ Yes, it allows for better F:R rotation.
    Nov 19 2006
    Ibis 07 A4 S-Line
    Quote Originally Posted by INTEGRATION View Post
    But no, I'm not going to raise my car... That's exactly the opposite of what I'd like to have happen
    Veteran Member Four Rings Rotond0000's Avatar
    Apr 30 2007
    Rhode Island
    keep rubbin
    - 2011 A4 2.0T Quattro - 6 Speed Manual - Black/Black - ST Coilovers - 20% Tint - Smoked Tails - Smoked Corners - 6000K Headlights And Fogs - Full LED Interior Lighting Conversion - Custom LED Headlight Strips - RS4 Grill W/ Blacked Out Euro Plate -
    AWD_4TW
    Quote Originally Posted by Pure Euro View Post
    Hey hey, my response was for the OP, not you! Stop whoring his thread up too- he was the one that made it!
    Nov 19 2006
    Ibis 07 A4 S-Line
    He shouldn't raise it either...
    Wheel gap FTL
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    hopefully the picture might help you as little
    the piece on the ground is the "carpet" i cut out using a dremel
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    Nov 19 2006
    Ibis 07 A4 S-Line
    Does the other piece now hang out-of-wack?
    AWD_4TW
    Wheel gap FTL
    After testing out some different specs and settings, I set it at a height which just so happened to have barely any wheel gap at all but I don't tuck.
    Nov 14 2006
    Gig Harbor, WA
    Your "camber" amuses me Brandon.
    -Darrick
    Dec 01 2007
    Markham, Ontario
    WOW that much carpet ? i am gonna let mine rub some more till it just stops
    Plus One
    Gabriel
    Markham Ontario
    Jan 14 2008
    San Antonio, TX
    Seriously takes like 1-1.5 hours or less. I'd help you out if you were closer
    Jan 14 2008
    B8.5 S4 - 6MT Sepang/Panda
    Calgary
    Did you notice it rubbing your tire a bit too? My fender liner was all screwed up on one side before I dropped my car, and only that side is rubbing, although enough I can see a tiny bit of wear on the tire. I'm hoping it's just the carpet and not the fender itself...
