Results 1 to 6 of 6
    Veteran Member Four Rings 99ebpsi24's Avatar
    May 04 2008
    10 S4 prestige, 12 A4 S-Line, 00 Stg3+ S4, 74 VW Thing, 74 Z28 camaro (32k original miles) 74 Z28 Ca
    Cincinnati
    Prob another dumb ? sorry
    like i said in my last thread i just bought my s4 a few days ago and its the first real hot day out and i noticed the temp gauge by the fuel gauge is a little further then half way to hot is that about normal temp for these cars? and the temp gauge at the bottom left of the cluster is still on the cool side not even half way to hot. is this normal?? thanks for your help!
    Veteran Member Three Rings DefiantS4's Avatar
    Jul 30 2004
    Houston, TX
    Re: Prob another dumb ? sorry
    The coolant temp gauge (next to the fuel gauge) should point straight up when 100% warmed up. The one on the far left is for oil temp. It should read just a few ticks higher than when cold. Sounds like you're fine.
    Past - '01.5 S4, APR Stage III
    Dec 12 2007
    Boston
    and don't go into boost until your oil temp is at least 1 tick from the bottom (~175).
    2001 S4
    Stage 3 totaled...
    new- 2001.5 Nogaro
    Veteran Member Four Rings 2001S4CT's Avatar
    Nov 17 2006
    Greenwich
    if the coolant temp is reading a little tad above middle then you might be sitting in traffic to long an as soon as you start driving ad air starts flowing it will come back down
    May 04 2008
    Cincinnati
    yeah it was one bar past straight up and i was sitting in the car after driving it from lunch break and noticed that it was a little warm and didnt know if that was normal or not. so from what i gather sounds like its fine but if it continues to run one bar past the straight up position is this something that i should get looked at or possibly check the coolant levels? sorry these may be completely retarded questions but i've always been a honda junkie and decided i needed to step it up a level so i picked this up and am trying to learn more and more about the car like i did with all my hondas
    Quote Originally Posted by 2001S4CT View Post
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    I would try flushing your coolant system. It isn't hard and it couldn't hurt.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
