Thread: Bolt Pattern
    Senior Member Three Rings 0330QA4's Avatar
    May 25 2007
    2009 VW CC Sport, 03 A4 (Sold)
    Ashburn Va
    Bolt Pattern
    Whats the bolt pattern and offest of the stock wheels on B8s?
    Registered Member Two Rings
    Apr 02 2008
    Europe
    Re: Bolt Pattern
    Quote Originally Posted by 0330QA4 View Post
    Wheel size 7x17, pattern 5x112, et 47.
    I´m running 8x19, et 35. On an eight inch rim et can easily be 30 and it won´t stick out.
    May 25 2007
    Ashburn Va
    Re: Bolt Pattern
    Awesome thats what I wanted to hear I just picked up some 18x8.5s for my B6 but plan on getting a B8 in the winter wanted to make sure I could keep the wheels. Thanks a lot for the help. I cant wait to get these in the states.
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    GTA Canada
    Re: Bolt Pattern
    Hub size is different on the B8. On the B6/7 it's 57.1mm, on the B8 it's 66.56mm (same as Mercedes).
    If the hubs on those wheels are larger than 66.56mm and you are using hub-centric rings to bring down the hub size to 57.1 on your wheels, you just new new rings. If those wheels have a 57.1mm hub then you are SOL.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
    May 25 2007
    Ashburn Va
    Re: Bolt Pattern
    Quote Originally Posted by MoroIsAnOrange View Post
    Damn Ill have to check.
