Results 1 to 7 of 7
    May 05 2008
    nor
    Change dashboard language german to english - VAG COM
    Hello,
    my friend got a Audi A4 TDI, 2003/2004 model, and it's imported from Germany. Since we are in Norway, we want english in displays...not german!!
    How to do that in VAG com?
    And: Does VagTacho work on this model?
    Established Member Two Rings bavaria75's Avatar
    Feb 13 2008
    02 A4 3.0QM - 04 Passat 1.8TM
    San Jose, CA
    Re: Change dashboard language german to english - VAG COM
    Here we go again,
    check out rossteck webpage on the possibilities. It's just software, sure it can be changed.
    http://www.ross-tech.com/vag-com/cars/audiB6.html
    The rosstech cable cost you 250USD or get a friend who has it in Norway. Not sure if your dealer will do it for you?
    2002 A4 3.0 Quattro Manual
    May 05 2008
    nor
    Thanks a lot!!!!
    No, in Norway, everthing, absolutely everthing costs and it costs HELL A LOT, when it comes to car things.
    I give you a price example: For an Audi A4 1.8L gasoline, 2001 mod, for an main service - with timing belt replacement etc- at 120.000KM they wanted 15.000KR ~ 3.000US$ .
    As you see, its a sick high priced service , or????
    i will try it on wednesday & give you feedback :)
    May 05 2008
    nor
    VagTacho on Audi A4 late 2003 model (2004) TDI
    Hello,
    Feb 13 2008
    San Jose, CA
    Quote Originally Posted by audinor View Post
    Thanks a lot!!!!
    You may fly a cheap mechanic in from Germany as well to do the job
    As for the Rosstech. I got the 10 USD cable from ebay and it gives you most of the options to change. I use it for error code read out and I changed my windows roll down with the key fob.
    Good luck with your 1.9TDI, good performance and cheap on gas.
    May 05 2008
    nor
    Yeah, really!!
    I got that cable to, from ebay, Hong Kong.
    Thank you for replies. Yeah, 1.9TDI is so good when it comes to torque and money saving on diesel. i have a VW Passat 1.9TDI 110hp, uses 5.0L/100km :)
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    damn near $4.15 for diesel in austin texas
    barrett
    2019 SQ5 Prestige
