Results 1 to 23 of 23
    Established Member Two Rings wat2022's Avatar
    Mar 24 2008
    04 S4,98 Jetta
    WA
    Steering noise when turning while braking?
    04 S4 Does anyone else have this problem? It doesn't happen all the time. Sounds like its low on pwr steering fluid but checked and it was full, and it only does it when you turn the wheel while braking,parking etc..
    Established Member Two Rings AudinLV's Avatar
    Jul 09 2007
    S6 RS6(RIP) S4 Ducati M Dark
    LV, NV
    Re: Steering noise when turning while braking?
    Yes!
    Senior Member Two Rings B6_Rakete's Avatar
    Apr 17 2008
    '04 S4 Avant 6sp, '06 330i 6sp
    I notice a low groaning noise when doing tight turns but usually only under a little bit power, not under braking. I think this has to do with the inside tires being spun faster by the drivetrain than they should be in tight circumference turns, causing them to loose traction a little bit.
    Are you sure you hear this sound under braking? If you try to replicate this sound with the clutch in/out of gear, do you still hear the noise?
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Yup I've heard it too.
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    Active Member Two Rings neo's Avatar
    Sep 19 2006
    Virginia USA
    Dude,
    You have got to bring to the audi shop. This was a recall. I had an issue like this and it was a steering system problem.
    Apr 17 2008
    Quote Originally Posted by neo View Post
    Dude,
    Any information on the recall bulletin ID? What exactly needed to be changed?
    Mar 15 2007
    2001 A4
    seattle
    i had a noise similar to this and the problem was my power steering pump was slowly chewing itself up and messed up the seals in my steering rack.. check your fluid for metal shavings i didnt notice mine till my pump was completely gone and the bill was over 4 grand
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Pretty sure thats the AWD system youre hearing
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    I have the same noise too, is this something that can be fixed?
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Sep 19 2006
    Virginia USA
    Yes. i believe it was the steering pump. You have got to bring your car in the shop.
    Apr 17 2008
    Quote Originally Posted by michaelo123 View Post
    If the noise was the steering pump, you would notice the sound the most when the car sitting stationary and turning the wheel from lock to lock. The power steering pump has to work the hardest when the car's not moving.
    I think it's the AWD system as well, where the diffs are not allowing the inside wheels to turn slowly enough to compensate for the turning radius.
    May 04 2008
    '04 S4 6spd / '04 Yukon Denali
    Westchester County, NY
    So if it is the AWD system - is that normal or a problem? I hear it everyday at very slow speed, with the wheels turned slighty to the right, pulling into a slightly upgrade parking space.
    Veteran Member Three Rings s4_fishingbean's Avatar
    Apr 13 2008
    B7 S4
    Ft. Lauderdale
    i have a b7...i had a whining noise of some sort...just needed more fluid in the power steering
    Mar 11 2008
    Pierceton, Indiana
    Lets just put it this way. Ive owned 3 quattros, and they all do that. Is it when you turn left AND right into tight parking spots, or make U turns of some sort?
    Apr 17 2008
    Quote Originally Posted by nimski62 View Post
    That's been my experience as well. To test this, find a parking lot, crank the wheel all the way over to one direction. Start driving smoothly, give it a little gas and once you get to about 70% of the maximum grip, give it a little more. You'll probably hear some low groaning from the inside tires if it's the same issue I'm familiar with.
    Senior Member Three Rings asurugger's Avatar
    Mar 12 2008
    2008 Cadillac Escalade
    Phoenix, AZ
    my brakes would grind when i was turning into a parking spot and applying the brakes. this was when i only had 500 miles on it. There was a recall on the front calipers...i think they told me that the bladder inside went bad? something like that but there was a recall and it is now fixed. so check into it.
    2016 Audi A6 Prestige
    Dec 05 2006
    So. Cal.
    All Quattro's do this. just don't do a full right/left lock. When you get to full lock, let off a little.
    Sep 28 2007
    San Jose, CA
    I had an issue where is sounded like squeeky brakes when I would make a sharp turn into a parking stall. Audi could not repro at first and then found it. They replaced my caliper seals I think.....I forget specifically but they said they weren't retracting all the way when coming off the brakes. Have not heard the noise again since. Not sure if this is what the others are refering to in terms of noise and the caliper issue...
    Registered Member One Ring sayporsha's Avatar
    May 07 2008
    Salem, OR
    My S4 makes the same sound, kind of a rumble when turning sharp at slow speeds, like in a parking lot. It sounds like limited slip differential clutch chatter. Different gear lube?
    Jeff
    Oct 14 2007
    Mammoth Lakes, Ca
    I just had mine checked out by Jose at Eurotech, it's not a steering pump issue. He checked everything associated with the steering, and she was fine.
    May 23 2007
    Port Moody BC Canada
    It's quite simple. TORSEN is Torque Sensing. No deceleration, no acceleration, no binding. Maintenance throttle is the key, or just live with the binding. Completely normal.
    Apr 17 2008
    Quote Originally Posted by Miah_TT_S4Avant View Post
    *boggles*
    What the heck does "Maintenance throttle" mean?
    Nov 04 2006
    05 S4
    LI, NY
    its not on U-turns or locking the steering wheel. Its very slow speeds.....usually backing out of a driveway or pulling into a parking spot. maybe 8mph or less. Steering wheel is slightly turned....1/2 turn or so and brakes being applied ever so slightly.
    Happens to me maybe once a week or so. First I thought it was my power steering pump. Checked and the fluid was a bit low so I added.....Went away for a bit and still doing it. Took it to the dealer and they told me I was rubbing the inner fender liner a bit so they adjusted it and it went away for maybe a month and a half.....now its back again.
    Its not a huge deal but can get annoying if someone is in the car. It sounds like a boat-horn...very low grunt. Almost as I just washed my car and stopped with wet rotors. But this isnt the case.....I dunno....I swear its the steering pump or something related to the rack but I cant prove it....and it doesnt happen that often to duplicate it.
    ITS NOT the normal noise you hear from the AWD system on U-turns
    Oetty roof spolier // FI Catback // Ecodes // Xenon Interiors // Solaris and LED Exteriors // Lower Euro-grille // ECS Snub // PSS9s // 19x8.5 BBS CH on 245 Potenzas // Euro RS4 Exclusive shift knob and Pedal Set // Carbon Fiber Trim // Custom Carbon Fiber Emblems
    Originally Posted by Justincredible
    "With the flux mod you can just put the supercharger in the trunk for extra traction"
