Results 1 to 9 of 9
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    The problems keep on coming (Driveline related)
    Just earlier this week I had my mechanic change the rear wheel bearing that was causing so much noise. Great. I was finally satisfied with my car being all fixed mechanically. Well, I was wrong. I pulled off my front drivers side wheel to find it gunked up with gear oil. That can only mean one thing- CV boot. Well, it looks like my boot is fully ripped. Can someone advise me how hard of a job it would be to fix this by myself and the tools needed? (I would be ordering the ECS boot kit) I am really tired of paying all the money I make to the mechanic .
    (BTW, I still love my car )
    Thanks
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Re: The problems keep on coming (Driveline related)
    Is it oil or grease?
    Gear oil indicates a problem other than an axle.
    If it's grease you've got a bad boot and need to replace the boot or axle.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Oct 25 2006
    oregon
    Just replace the axle itself. Rebooting is a PITA, and you can find remanufactured axles from parts stores for very cheap, otherwise Raxles I've heard very good things about. Overall all it is a quick simple job.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    raxles.com will get you a full replacement axle with new CV joints installed and it comes with installation stuff like lube and gloves. You basically turn the wheel all the way and pop the axle out and slide the new one in. There are some more details and fasteners and whatnot but that is basically it. The only tough part is the massive hex bolt that holds the whole thing together. It is under the dust cap on the wheel and I had to have a garage blast it off with a big impact gun and then re-torque it so I could drive it home and get it off myself.
    Jim
    I Do Werk.
    Veteran Member Four Rings loustylez's Avatar
    Oct 03 2006
    2001 A4 2.8 QT
    kansas city
    the job for me was a nightmare but that's because i f'd up the splines of the CV going back into the hub because i didn't get it in all the way before starting the car and reversing out of the garage.
    this job SHOULD be easy if you do it right. if you want the experience, definitely go for it. helps to have someone else turn the wheel for you while you knock the TRE and upper control arm links out in order to get the hub back far enough. just follow the DIY on audiworld and it should be pretty straight forward.
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    if you're not clicking as you turn, just replace the outer boot. just like any other vw axle. remove the axle with the 6 inner bolts holding it in. throw it on a vise and carefully hammer out the outer joint with boot still on. the boot acts as a cushion for the hammer. new c clip & boot & grease and you're in business. hardest part is removing the axle bolt.
    82mm je pistons, scat rods, ported & polished aeb head. gt2871r, atp hi flow manifold (ported). 580cc injectors on custom giac tune. Once you boost, you'll never go back....
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Sorry guys. I've been away from this thread. The thing with my car is that its more like a whirring sound than it is a clicking. I really only notice it in low speeds.
    Soon to be BT...
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Dont buy aftermarket axles. Theres a big reason why they are so much cheaper!!! Reboot it!
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Quote Originally Posted by quattro16 View Post
    Thats what I'm thinking.. It's still only a barely noticeable sound from it so it may be fine to just re-grease it with a new boot..
    Soon to be BT...
