Results 1 to 30 of 30
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    Tip tranny stoped working......WHY?
    So im driving my car today, and i go up this hill and nothing happens, the car revs high and wont move, i turn it off , turn it back on, still nothing, the car can go in reverse but wont move in first gear, i had to get it towed home and now gota find a tranny shop, i tell you this car has been giving me more problems than anything i have ever seen, and i dont even drive it hard, but do any of you have any idea what this could be???
    2004 Audi A6 2.7T
    Veteran Member Four Rings Gigi's Avatar
    Jan 23 2006
    2004 Audi A6 2.7T, 1999 Jeep W
    Charlotte, NC
    Re: Tip tranny stoped working......WHY?
    did you recently put on a tip chip?
    Did it feel like it dumped into a gear (clunking sound) while driving, maybe 4th, and you ahve to accelerate a lot to get it to move forward?
    When mine did that, it was the trany going into limp mode to protect itself.
    Have a great day, Brice
    99 Jeep TJ, 4" lift, Mikey Thompson rims & tires
    http://i157.photobucket.com/albums/t...i/photo-22.jpg
    http://i157.photobucket.com/albums/t...20TJ/Jeep2.jpg
    SOLD: 04 Blue [B]A6 2.7TStage 2 +: Many mods
    Mar 30 2008
    Pittsburgh
    no, it just wont move, and the gears have the red box around them, and the check engine light came on. And i had to push down very far, like maybe 4k rpm just to get it to go 5mph
    2004 Audi A6 2.7T
    Jan 23 2006
    Charlotte, NC
    MMM do you have the AR chip and a tip A6?
    If so, have you latrely changes from stock to chipped or vice versa...?
    Veteran Member Three Rings RAUDIS6's Avatar
    Oct 09 2006
    Stage 3 B5 S4, LS460, Mini S Countryman
    Quote Originally Posted by Gigi View Post
    What do you do to get it our of limp mode? Mine is starting to have the hesitation that it does not want to get out of gear, holds the RPM's longer then slams into next gear...only does it sometimes.
    Mar 30 2008
    Pittsburgh
    no chips at all.
    2004 Audi A6 2.7T
    Jan 23 2006
    Charlotte, NC
    sounds like you may be in limp mode for some reason!Did you pull the codes yet?
    Mar 30 2008
    Pittsburgh
    man i have no idea about what your talking about, lol, all i know is the car is fucked and wont move, i have no chips and didnt do anything to it, could have somthing broke?
    2004 Audi A6 2.7T
    Jan 23 2006
    Charlotte, NC
    hmmm well you have low mileage right?
    I dunno but I doubt you killed the tranny... Maybe something small but enough for the tranny to go im limp mode to protect itself...
    hard to say without seeing the car, having the codes...
    Mar 30 2008
    Pittsburgh
    it only has 69K on it, it couldn't be the tranny, and nothing is leaking
    2004 Audi A6 2.7T
    Established Member Two Rings Digga's Avatar
    Jun 18 2007
    FL
    This may have nothing to do with it but 69k..... did you already have the TB replaced?
    Although if it was broke it probably wouldn't move at all.... just trying to help think of possibilities
    Current
    FOR SALE
    2013 BMW 335i M Sport
    MPE/Dinan springs/Rotiform
    http://f30.bimmerpost.com/forums/sho...d.php?t=998376
    Former
    04' A6 2.7T ~APR 93 OCT Tuned
    -APR R1 DV's, Eibach Sportlines, RS6 lip spoiler
    Aug 30 2007
    nyc
    my tranny pump blew a seal and i got a stuck tc code..... check the pan and tranny fluid... scan for codes... if you get stuck tc code fill her up with atf........... make sure you giot trans fluid.........
    c5 A6 tip
    this n that
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    Pull the codes and post em up here. if you have DTC17125, do NOT drive the car, even if it comes out of limp mode. Once we see the codes we can better advise you.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Mar 30 2008
    Pittsburgh
    how do you "pull" the codes?
    2004 Audi A6 2.7T
    Mar 30 2008
    Pittsburgh
    Quote Originally Posted by Digga View Post
    It wont move, but it goes in reverse.
    2004 Audi A6 2.7T
    Registered Member Three Rings m-avant's Avatar
    Aug 05 2007
    cars with wheels...
    Californication
    Quote Originally Posted by FrankA6 View Post
    I use a VAG-COM(Key-Com cable) to pull codes from my car. If you don't have access to one, your local AutoZone should have a reader that would be able to pull the DTC. The software I use was downloaded here:http://www.ross-tech.com/vag-com/index.html
    When my torque converter went south, it threw a check engine light before it failed. It worked fine in "D", but would act strange in tiptronic mode. It had about 40K when the torque converter was replaced.
    ./mac
    baby hauler:2003 A6
    the daily: 2007 GTI
    track rig:99 M3
    old Avant (missed dearly) :2000 A4
    Jan 23 2006
    Charlotte, NC
    I had the same thing happen twice:
    - after installing the stg3 tip chip, was an ecryption issue
    - after switching fomr stock to chip or vice versa on APR CC switch
    But yuo don't have either...
    It does soun like you're in limp mode so the tranny knows to protect, don't drive it.
    YOu ahve to get a code reader even if a chepa $40 one like mine or the VAG
    I am waiting for my VAG TOOL :)
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    something like that happened to me but it was a broken axle = (
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Mar 30 2008
    Pittsburgh
    Took it to a local indy shop today, they vaged it and restet and everything is fine now, just threw a code!!!! thank god!
    2004 Audi A6 2.7T
    Registered Member Two Rings AAAA4's Avatar
    Sep 27 2006
    96 monster Tacoma, 04 A6 Sline
    what was the code?
    2004 A6 2.7t s-line-current project
    2005.5 A4 2.0t -sold =(
    Apr 18 2007
    ny
    Quote Originally Posted by m-avant View Post
    I just got my torque converter replacd yesturday after I threw 17125 under warranty thank god. One question, have you had any trouble since the tc change, how has your car changed?? Im really pissed that they had to drop my tranny and swap out my tc at 45k
    Apr 21 2008
    Central New Jersey
    Quote Originally Posted by A62TURBO View Post
    There is a good chance your Tranny could go too. When the TC's seal goes bad, it overpressurizes the transmission and ruins it. That is why I advised you to not drive the car if you had the "death code"
    make sure this is documented with your dealer and AoA.
    How far did you drive it AFTER the code was cleared?
    Apr 18 2007
    ny
    Quote Originally Posted by skiroad'r View Post
    Well it threw the code on Monday afternoon and I only drove it the next morning to Audi. I don't know what to do now, I have about 10 months left on my CPO warranty and I know that as soon as the warranty expires my tranny will go bad lol
    Apr 21 2008
    Central New Jersey
    That's ok as long as the repair is documented with your dealer and AoA. Let's say your tranny craps out in 12 months, 2 months after warranty is done. As long as this repair is documented, AoA will very likely grant you a goodwill repair.
    My suggestion is to call AoA and tell them your TC was recently replaced and you are very pleased with the service your dealer provided, however, based on other's experience, you are concerned about related transmission problems down the road. get them to document the repair and provide you with a case file # that you can reference in the future.
    And to ease your fears, if you did not drive the car much, you should be ok. And if the transmission is bad, it will probably go quickly.
    Apr 18 2007
    ny
    Thanx for easing my fears, I will call AoA today. Just out of curiosity, where in New York do you live? I live in Whitestone, Queens.
    Apr 21 2008
    Central New Jersey
    np, when you think of all the things that might go wrong with the car it gets scary. I'm in Manhattan on the Upper West. My mom grew up in Queens, my uncle still lives in Bayside.
    Senior Member Three Rings Chopstixs's Avatar
    Jan 22 2008
    2.8 Single Turboed A6/2011 Tahoe
    Va
    Frank...Still waiting for the code it threw!
    Through out the years, People have used "Chopstix" to eat rice.........I do the same.
    C5 UNION MEMBER
    Mar 30 2008
    Pittsburgh
    oh i have no idea, the guy at my local indy VW/Audi garage did it :(
    2004 Audi A6 2.7T
    Aug 30 2007
    nyc
    i hope u didnt reset the code and it has low fluid.............. lol
    c5 A6 tip
    this n that
    Mar 30 2008
    Pittsburgh
    no, we found out why it trew a code, they guy i took it to , to do the springs/shocks, ran it on a lift, to listen for a noise i was geting, and i guess somehow the front wheels turned but the rears didn't. the guy at the indy garage said, the code come back, somthing like "error in gear ratio" or somthing, he checked the fluid, and it runs just fine, just a small little glitch i guess.
    2004 Audi A6 2.7T
