Results 1 to 9 of 9
    Senior Member Two Rings algee007's Avatar
    Apr 10 2008
    B6 S4
    DENVER
    Need Help Finding DIY Oil Change for B6 S4
    Hey guys, I recently picked up an 04 S4 and I'm not too sure if the dealer changed the oil, and before it's too late I'd like to change it myself. I used to own an A6 2.7T and changed my oil all the time, now that I'll need 10qts and a new filter application, I was wondering if anyone can shed some light on the situation. I was hoping to find a DIY on the filter change but came up with nothing. Can anyone help with the location of the oil filter or some photos??? It would be much appreciated. Thanks
    Established Member Two Rings JohnnyG's Avatar
    May 03 2008
    too many....my audi: a4 b8.5 project
    LongIsland, NY
    Re: Need Help Finding DIY Oil Change for B6 S4
    easy job pull the engine trim over your tb ......24mm cap on a cartridge oil filter setup. replace the oring, drain is a 10mm hex and a crush washer (replace) washer comes separate from filter. do not add 10qts. add 8 start for 15 sec, check and top off as required. enjoy
    Apr 10 2008
    B6 S4
    DENVER
    Thanks...I was thinking the replacement filter by the oil pan like the A6....I was under the car today...and I was like what the F???? but now I see the light, thanks
    Veteran Member Three Rings manhattanprjkt8's Avatar
    Jun 22 2008
    Lots of blown out mounain bikes
    pennsyltucky
    i havent jacked my car up but i just got it yesterday and want to do an oil change first thing, is the plug right there in plain sight?
    I like the 8 qt suggestion, makes sense.
    Registered Member Two Rings swoyekr.'s Avatar
    Feb 21 2008
    SE PA
    changing the oil in these things is a piece of cake. They take ALOT of oil too.
    04 s4 - .Milltek catback SOLD
    Current daily - RSX TYPE S
    Veteran Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2007 Audi RS4 (Gone), 2005 Audi S4 (Gone), 2002 Audi S4 (Gone)
    Dutchess County, NY
    Quote Originally Posted by swoyekr. View Post
    You got that straight!
    2000 Audi A4 Race Car, 2014 Audi SQ5 (Daily)
    Run Silent, Run Swift...
    Senior Member Two Rings 04s4's Avatar
    Aug 10 2005
    2004 S4
    HI>CA
    make sure you get a crush washer first, if you can't get an audi one, the Volkswagen Touraeg fits too, you just need one. You better off buying oil in 5 quart containers, they take about 8 quarts, maybe more. Also make sure you put the underbody panel back on properly, mines fell off somehow.
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Here's how I change mine.
    Steve
    Quote Originally Posted by S4J View Post
    Hi All,
    I changed my oil and filter this morning. It took me 17 minutes with my larger capacity Pela Pro 14 oil extractor (I sold my smaller one to a friend).
    I though I'd share the products I used for those interested…
    The extractor is extremely easy to use (make sure the oil is warm, not hot). Just push the correct sized tube (you get three) down the dip-stick hole to the bottom and pump the handle a few times to create a vacuum. The tubes they provide aren’t quite long enough so you’ll have to raise the extractor off the groung a bit by placing it on a box or something. I use a plastic milk crate. While the oil is extracting I replace the oil filter. The filter is located on top of the engine, under the trim cover with the Audi logo, at the rear. You’ll see a black plastic domed cover with a plastic nut molded into the top…the filter is inside.
    NEW- PELA PRO 14 LITER OIL EXTRACTOR
    $109 Shipped from http://www.eAngler.com
    OLD- PELA EXTRACTOR $79 from Griot’s Garage (fine for my Z, but too small for the S4)
    OIL
    Lubro Moly VOLL-Synthese (5 W-40 Full Synthetic Motor Oil) - 5 Litres x2, $35 ea. ($83.38 shipped) from http://catalog.etyparts.com/item.wws...y&clientid=ety
    FILTER
    Mann HU 835/1 x oil filter, $15.53 ea (pack of 4, $62.12 shipped) http://www.germanfilters.com/2004-au...k-p-55729.html
    I also purchased a fuel filter but haven't installed it (I haven’t looked in to where it’s located...anyone done it?).
    Mann WK 730/1 fuel filter for 2004 Audi S4 with 4.2 V8 engine
    $12.58 each from http://www.germanfilters.com/2004-au...r-p-47526.html
    Hope this helps, have a good one…Steve
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    x2 on the extractor. You shouldn't have a lot/any of sediment at the bottom of the pan if you change it while the car is warm (just after a drive).
    Cool stuff with a little growl!
