Results 1 to 10 of 10
    Veteran Member Four Rings SLYCAT's Avatar
    Sep 26 2007
    Augusta
    Exclamation Forge DV Owners Beware!!!!!
    Not bashing Forge by any means, just letting Forge DV owners know that the top of the valve backs out with time and vibration. Thanks to the two coolest guys I know Jake(jakecro) and James(offroader106) I was able to solve my boost issues. Dropped 10 PSI going to Quattro De Mayo and had to limp back home. They found the loose DV and used some good ole thread lock and now I'm good as new. Hopefully this is a permanent fix. Thanks guys.
    Veteran Member Three Rings jojogoya88's Avatar
    Jan 02 2007
    new york LI
    Re: Forge DV Owners Beware!!!!!
    What is this "thread lock"....
    E90 M3!!! Interlagos
    Audi A4 B7 6spd S-Line Titanium Pk. SOLD
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    thread lock like loctite red (permanent) or blue (semi-permanent)
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Veteran Member Three Rings gyroscope's Avatar
    Mar 19 2007
    06 A4 S-Line Quattro, 98 K1200RS, 21 GTI SE DSG
    Queens, NY/Poconos, PA
    If I'm not mistaken, Forge reccomends that you use thread lock during the install. And if thats the case, their product is not the problem. The problem is the person who installed it.
    Jan 02 2007
    new york LI
    ohhh yeah i used those on the install...
    its that unscrew n screwing part that over time becomes loosened, which was my problem
    Registered Member Four Rings 4-tified's Avatar
    Sep 18 2006
    A4 2.0T Quattro
    Chicago
    Quote Originally Posted by gyroscope View Post
    I've read that the valve itself comes apart after a while.
    Why should the owner/buyer have to do final assembly of the valve to install it? The stock DV comes as one piece and you install it.
    An aftermarket DV should come assembled, and properly.
    Maybe I'm missing something?
    Veteran Member Three Rings scoobycarolan's Avatar
    Nov 02 2007
    Albany, NY
    I agree, for a part that expensive no assembly required.
    Sep 26 2007
    Augusta
    Yep I put like a 150 miles on it so far, still good but you definetly gotta keep an eye on it. Which I think should'nt be for $225 plus labor.
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    good info .. I will deff have to have mine checked out ! thx fellas
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    for the amount of hassel i went through putting my forge dv on, it better not go on me...i will be PISSED
