here is my situation. i bought the car with some of the mods below: Piper Cams, GIAC chip, Borla catback, FMIC, atmosphere vented BOV, and an adjustable FPR. It also came with a solid CEL
the car misfires bad at idle in all cyls, most dominantly in cyl 4, then 2, then 1, then 3, with VAG readouts i can watch them climb by the second...really fast
also, on a cold motor i will have hesitation / stutter from idle to ~2000 rpm, after that it will remember to drive and go well....this isnt there when its warm, but idle misfires are
my readouts usually look like this:
5 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4 Misfire Detected
P0304 - 35-00 - -
16686 - Cylinder 2 Misfire Detected
P0302 - 35-00 - -
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
P0300 - 35-00 - -
P0304 - 35-00 - -
P0302 - 35-00 - -
- Spark plugs with NGK BRK7E 0.028 gap (did not help, now running Bosch F6DTC triple electrodes)
- ICM / power stage module
- all 4 coil packs
- engine coolant temp sensor
- cleaned MAF (with spray)
- checked and re-wrapped coil pack harness with silicone wrap
- intake manifold injector seats
- injector o-rings
i am waiting on the hose to reroute the DV back into the TIP, until then I am running the BOV still and will put the DV in soon
the car is on temp tags till the 17th, been playing with this issue since march 17th, so i would really like some help if anyone can....
thanks!
