Results 1 to 6 of 6
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Question Throttle Body and more
    What are the benifits to upgrading the 1.8 throttle body to a 2.7 or VR6? Better throttle response? More air? If you do upgrade it can an aftermarket fmic (racetec) still fit it? Also will it mess with the ecu (giac j31)? Just curious.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Throttle Body
    Not going to see all that much of a gain in power doing it with a K04 which just isn't out flowing the stock 1.8 throttle body.
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: Throttle Body
    Depends if the vehicle is DBC or DBW mike.
    On the DBC cars there will be a significant gain as the throttle plate on the AEB throttle body is approx 52mm....whereas on the DBW it is 60mm.
    The S4 throttle body is DBW is only 65mm and the only other upgrades above this are 75mm and 80mm.
    If you have a DBC car go for it.
    If you have a DBW car upgrade your turbocharger first.
    Jul 07 2004
    socal
    Re: Throttle Body
    Quote Originally Posted by Issam@034 View Post
    J31 = 2000 = DBW.
    Oct 20 2007
    Re: Throttle Body
    Thanks to both of you.
    So what are some other ways to get more hp out of a ko4?
    So far I have..
    Atp exhaust manifold
    K04
    Giac j31
    Injectors
    Ebc
    Afpr
    Carbonio
    Forge 007
    and some other unimportant goodies such as HKS TT, etc...
    I still need my fmic before I install all this.
    I know I would benefit from an exhaust and a hfc which I am planing on getting this summer (borla and labree) but what else is there?
    I heard water/meth but is it really worth it on a K04?
    Also what about port/polishing the exhaust manifold?
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    Re: Throttle Body and more
    is anyone aware of a larger bore throttle body that is a direct replacement for the AEB?
